been using BP ultimate for the last 3 tankfulls and milage has increase from 8.4km/ltr now to 8.8km/ltr ....really impressed that a simple fuel change can give better milage....then again BP is normally 5-10cents higher than any other fuel with the same RON ratings
Edited by fcruz3r
Found this thread on another forum
Which Fuel? Heard the saying "You are what you eat"?
Use the highest octane fuel you can. After speaking directly to fuel distributors, wholesalers etc I found out the following info,
All W.A. fuel comes the BP refinery in Kwinana. Which would mean that it doesn't matter which Petrol Station company you go to to fill up at as all the fuel comes from the same place, right?
Wrong!!!
Its not the refinery that matters. Each company adds in their own 'secret' additives to improve the fuel. Each company states that their mix is better than their competitor but as long as the octane reading is the same, eg; BP Ultimate 98 (98 Octane) then it doesn't matter.
Where the issue lies is with the individual Petrol Station. This means one BP could be different to another.
What am I talking about you ask, well let me explain.
For example, a BP in Armadale (building) could be only 5 years old since the last refurbishment, but how old are the underground storage drums that the fuel sits in? Some distributors I spoke to stated some petrol stations have storage drums 20 to 30 years old. These drums over time have sediment build up, water may of leaked into them and most importantly how often are these drums cleaned and inspected???
This is the place where fuel may be contaminated.
It obviously costs a large amount of money to service and clean the drums, so usually only the distributor owned stations are done. (I'm not saying privately owned ones don't get done, but not as stringent and often).
Why does each companys fuel have a different colour? This is because they put a dye in the fuel as to be able to distinguish between theirs and another companies should there be a complaint received or issue with the fuel.
The best advice they could give me was;
1. Find a Company, (BP, Shell etc) and fuel type (BP Ultimate etc) that your happy to use.
2. Always try and fill up at the same petrol station. (You would then obviously know which station has given you bad fuel)
3. Try not to mix you fuels between companies.
Hope this helps.
Madmax
You are primarily correct max, all major fuels do come from the BP refinery & Kewdale terminals but they don't clean out the tanks at the stations. Rarely they may pump out the water which is heavier than fuel and sits at the bottom of the tanks with the sediments. Each station has alarms for each tank that are set to go off when the tanks get down to 5000L (can't remember exact amount, may be more). The problems with contamination arise when the attendants ignore the alarms and let the tank drain to the sediment level. The somewhat expensive pumps not only fill your tank with shite but also fail within a very short time frame. Also avoid filling up at a station that is doing the same, sediments get stirred up by the tankers.
BP/Shell premiums are actually about as good as it gets. The independants just water it down so to speak.
Courtesy of a conversation about fuels I had with a state manager for BP my brother in law, so it's not BS.
  • 4 weeks later...
from what I understand, the bowser pick-ups actually float on the surface of the fuel, so unless the tank is all but empty water shouldn't enter the bowser.
My Mobil fuel station, has in the past closed the Synergy 8000 (98 Octane) pumps for this reason.
I think that is what a mate told me and he tests the tanks for a living. They also need to be 'leak' tested by using air under pressure with leak down figures to be followed closely, so in theory, nothing can be introduced into the tank.
Pumps are generally submersible. Sediments and water are introduced thru' the filling point of the tank. Like I said, these pumps get dead very quickly when the attendant ignores the alarm and lets the tank get below the minimum level. The pumps at $6-7k each are not something the supplier wants to be replacing too often, particularly when on top of that they have the cost to rebuild a clients motor as well (this has happened to BP).
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
