For sale:
HR31 1986 Nissan Skyline.
Current engine is an R32 Silver top ECCS RB20DET with factory turbo. Engine currently has 90K on the clock
The half cut came with a MINES computer which is currently installed (No boost cut, no rev limit, and no speed limiter @ 180km/h
Turbosmart Mechanical Boost bleeder "T". Currently running 12psi
Car has been dyno'd at 133rwKW with fairly rich AF ratio's due to jap MINES tuning.
K&N pod filter with new R32 flow meter
Uses the factory R31 "side mount" intercooler.
R32 GTS-T gearbox
Exedy HD sports clutch
Autometer Boost Gauge mounted on steering column.
GoFastBits plumb back blow off valve
Recoed power steering rack
New ball joints, and castor rod bushes
4 x Bilstein shocks (with the big shaft), fronts have just recently been serviced by Quadrant and are in excellent condition
Viscous R200 LSD (getting a little tired, and probably ready for a 1.5 or 2 way Kaaz! :twisted: )
GTS-R BBS alloy Japanese wheels with Bridgestone GIII tyres
Factory 4WS is currently operational.
Air-conditioning has recently been serviced and re-gassed
EBC green stuff pads on the front, Bendix Ultimates on the rear.
Full 3" exhaust from the turbo back with CAT/resonator and stainless muffler. Sounds EXCELLENT (Ringwood performance exhaust)
6 x new spark plugs fitted
Water pump has been replaced, and the timing belt has been replaced with a GATES belt.
Has a Panasonic head unit with Panasonic 6" speakers in the front, and 6" in the rear. Also has two amps and one 10" Kenwood sub in the boot in it's own box. I've always been meaning to remove this to get more boot space, but never got around to it due to building the 1600!!!
Item Condition:
Excellent condition throughout.
Stone chips on the front of the bonnet.
Overall the car is in excellent condition and has been meticulously maintained. The car has been used as my daily driver and as I live in whoop whoop, I have cranked over a few k's in it.
I have serviced the car every 5000 with synthetic oil (Penrite 10W40), filters, plug gap check, AFM clean etc. etc. The alternate 5K, the car has been professionally serviced to fix anything that I didn't have time for as I was rebuilding the 1600.
There are only a few things to get the car RWC, and I will have these done very soon. (replace windscreen, get one of the dash lights working again, fix the recently recoed power steering rack leak - WARRANTY!!!, and loose cover of the steering wheel)
May consider selling without RWC, but really it's so close, and most of it is fairly straight forward.
Rego is August next year.
Currently insured with Shannons
Original white paint! (in very good condition except for the stone chips on the front of the bonnet)
I really don't want to sell as I really love driving this car and would loved to have turned it into a white GTS-R, but I'm thinking of getting a Stagea station wagon, and as the 1600 only has two seats, I can't have two 'coupes' damn it. :D
Price and price conditions:
$9500 with RWC
Extra Info:
I think the information above covers most things
Contact Details:
PM me on this site, or reply to this post.
PH: 9566 1686 during BH. PM me and I will give you my mobile number.
Car is located in Bayswater, but can be located in Sunbury if necessary.
Delivery & Conditions of Delivery:
Might arrange transport to another state
Pictures:
See below.
https://www.sau.com.au/forums/topic/298434-fs-hr31-nissan-skyline-vic/
Steering rack has been fixed! Front wheel alignment is being done today.
Deposit from prospective buyer will be taken before the windscreen is replaced...
Steering wheel has been removed and is being re-glued and re-stitched. (road worthy item)
Final item is the windscreen...
I am interested in taking a deposit first before tackling this one, or might do it in the new year when everyone isn't so busy.
Offers without the RWC might be taken, but as stated previously it's so close, the extra $300 for a windscreen and fitment isn't going to be much of a discount. Although open to suggestions (and swaps + Cash for a stagea!)
Alot of interest for swaps, but unfortunately nobody with a Stagea. I might consider a Mitsubishi VR4 Legnum with low kays and cash in your direction...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
