This is my sad little attempt to take a half decent photo and i failed :)
I took a whole bunch out last night just goofing around with my camera
my tripod failed and i dont have a shutter release cord
ps. i dont have photoshop atm...and when i was taking the pics everyone was getting eaten by mosquitoes...so i got hurried up :D
and i managed to photograph a ghost aka my mate blair running around in front of the camera
Edited by Passive
  • Replies 87
Posted Images
snaps with the new 17-85mm lens i got
missed a couple of the noise spots in photoshop in the first one, and saving it to a lower quality jpeg f**ked with it a little
First time ive ever attempted taking and/or editing these types of photos so throw me some tips if you have any :D
Edited by stenve
Nice work Tabby! I took some shots from Kings Park as well, but without a tripod not one turned out good :) In the 2nd one (looks kinda trippy :D) the lights in the shadow looks a better and less over exposed. I had the same issue, the street lights look awesome, but the bigger signs are unable to be read.
Constructive criticism: there's no real focus point in the photos (which is, admittedly, pretty hard to set at night). That and the camera shake wouldn't have helped. Also, the trees on the bottom-left of the photos take up too much of the shot.
If you do have a tripod but not a cable release, the next best thing to use when you've composed your shot is the self-timer on the camera itself. Put your camera on the tripod, set the timer to 10sec, compose the photo, and then trigger it to shoot. The 10sec margin should give the tripod and camera plenty of time to settle any movement before the actual shot is taken.
Hey thanks for the advice!!! (camera timer)
never thought of that
yeah the photos are crap IMHO :)
but i had my bf, mate and his 'gf' there and they were whining about mosquitoes, so i didnt get much of a chance to screw around
also the crappy tripod wouldnt tilt any higher
i'll try the timer thing next time
yeah the photos are crap IMHO :D
Instead of tilting the tripod higher I would probably zoom in a bit instead if you can.
Try cropping the top and bottom of the picture a bit (prob a bit more at the bottom)
thats what i was going to leave mine as but those damn sulpher lights are too bright. so did in-camera conversion and looked heaps better so left it like that!
and i saw it earlier in the night heading nth, so coming back i had to stop off and take it!
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
