Hi guys i have just had my brake rotors front and back machined and had new hawk hps brake pads fitted to my v35 with brembos now it doesn't have any bite and stops very poorly, is this because it has all just been done and will get better soon or am i know stuck with a set of brakes which barely stop?
Did they change your brake fluid? Could there be air in the system? I know we had to bleed my friends car for ages for all the air to come out and then it was braking alot better.
Just a suggestion.
As suggested, bleed the brake fluid first. It could be air in the system.
FYI we fitted a set of Hawk HPS' to my girlfriend's MX5 and the performance was horrible. There was no initial bite when cold (and it was still worse than stock on the track when you got heat into them) and maximum braking didn't feel that much better.
When we first fitted them we had a few instances where we almost arse-ended another car because the amount of pedal pressure we were used to applying from the stock pads weren't pulling up the car.
I will not be getting another set of those pads.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
