This thread is not for whoring/chat
The management has informed me that show entrants are to be at the venue by 8am
We will be meeting up at the Hawksbury off ramp opposite the truck stop on the F3 as marked on the maps below.
Arrive at 7am, leave at 7:20am - No exemptions.
I will be there with Fat-Lad and his wife Kacey in their Silver Stagea, we will be leading the group to the venue from the meet point.
Please make sure you have a full tank of fuel and a full stomach of breakfast before coming to the meet point. We will not be making any stops from when we leave the meet point to when we get to the venue.
please call 0414 714 048 and notify me if you are running late and we will wait for you.
If you are meeting up please post in this thread.
Suggestions/comments are welcome. :)
https://www.sau.com.au/forums/topic/299490-novocastrains-coasties/
Hey guys
We'll be passing through about 7:15 - 7:20, I'm gonna let Xmetal know when we're a few mins away, so that everyone can get into gear & "LINE" up with us all :(
Sorry that we cant really pull over, we're on a bit of a tight schedual, Im sorta doubting that we'll make it there by the 8:30 meetup - just down the road from the grounds..
We could be a bit late if traffic gets bad..
which way you guys going when you get to hornsby?
via penno road or through city?
i would've thought going through Pennant Hills is the most direct route. So ill be waiting on Pennant Hills Road and join you guys there when/if you drive past :D . Is there another Stopping point? Or straight through to Fairfield?
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
