Took my rb30 in for a tune today and on the second run the check engine light came up.
I dont have an oil pressure gauge on the car so we put on one and its showing no oil pressure at all. The tuner said he didnt hear any knocking noises what so ever and typically with a big end there will be pressure.
We are thinking perhaps the crank collar is slipping inside the oil pump (rb30 crank with collar and 33 gtr pump) or perhaps the oil pickup has rattled loose?
Have yet to go and get the car and rip it to bits, but would be keen to get any ideas?
Thanks
https://www.sau.com.au/forums/topic/299666-no-oil-pressure/
smashed the oil pump gear by the sounds of it.
Get an oil test done and you should get high PQ levels which would indicate ferrous material in the oil other than bearings.
Obviously high levels of copper and lead will indicate bearing failure as a result of this.
Wear Check Australia are the people to call for the test kits, cost about $35-40 and takes a few days to get the results.
Don't dump the oil out of it until the test sample is taken
https://www.sau.com.au/forums/topic/299666-no-oil-pressure/#findComment-4980733
Thanks for the reply. Im in New Zealand so have no idea where i would do this. What is wrong with taking off the sump to check and what is likely to have happened to my engine if this is the case? Is it a case of throwing in new big ends fixing the oil pump and collar etc and going again from there??? If the gear is cracked will this cause no oil pressure at all?
The engine was rebuilt a max of 2000kms ago with a new crank collar and 33gtr oil pump so im quite suprised this may be the issue. Keen to ideas though so thanks heaps.
Would a seal cause no pressure at all????? Sounds unlikely but will let you know.
https://www.sau.com.au/forums/topic/299666-no-oil-pressure/#findComment-4980958
Where you would do this? I just told you the name of the place to get it from.
You can pull the sump off and do all the rest of it if you like but oil tests tell you what has gone wrong, how bad it is and whether you need to buy bearings etc or just another oil pump.
If the engine was at full load and the gear smashed (not cracked), then the bearings are likely to be stuffed also, if the crank has been damaged, you can't just throw new bearings on it and away you go.
If it's an N1 pump then it's even more likely that the gear has smashed. I would go back and see your engine builder before you do anything else. If you start pulling shit apart, say goodbye to any warranty they might give you.
If the collar wasn't install correctly, then you have other issues...like having to buy a new crank
No a leaking seal will not cause 0 oil pressure and the pickup design is the same throughout all RB's so I doubt it would be that. It's not a pressure side anyway so there is minimal sealing needed by it in the first place.
https://www.sau.com.au/forums/topic/299666-no-oil-pressure/#findComment-4981620
Or:
Shell Head Office:
3 Queens Wharf, Wellington, New Zealand
Postal Address:
PO Box 2091, Wellington 6011, New Zealand
Telephone:
Customer Service Centre for all customer enquiries: 0800 474 355 (0800 4 SHELL)
Head Office for all corporate enquiries: 04 472 0080
Apparently they do oil analysis also.
https://www.sau.com.au/forums/topic/299666-no-oil-pressure/#findComment-4981622
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
