Hey Guys, looking to purchase some new tyres very soon but im not too sure what to get. Was set on the KU31's since I've heard a lot of good things about them. Plus they are very cheap. I have however heard they are noisy?? Apparently they KU19 is much quieter however its also a softer compound and therefore wont last as long...So I've heard.
Car is a daily and I need the tyres to last long. Hoping for like 30K. Anyone have personal experience with both tyres that can give a comparison?
Cheers guys
https://www.sau.com.au/forums/topic/299720-ku19-or-ku31/
Hey mate, I'm looking for the exact same thing at the moment, where are you getting them cheap as they don't look that cheap on their website???
I'm after tyres for stock R34 gtr rims and was thinkin of 265/35/18 as the stock 245/40/18 don't cover the full width of the rim properly...
https://www.sau.com.au/forums/topic/299720-ku19-or-ku31/#findComment-4985995
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
