hey, just a heads up u can buy the 7.1L Monaro,
but it isn't called a monaro it is somesort of HSV with 427 in it, similar to the monaro use in the race
Your a knob! Holden will never build a 7L monaro EVER!
Nissan need to bring a GT500 GTR over to race, then it will be able to compete fairly with the 427 HRT or this year i mean CV8 monaro
Holden were going to sell the HRT 427 but it became too expensive and they called it off. It was going to have a production run of 100 cars or something. I read this in the drive section of the paper about a year ago, so it must be true. :rolleyes:
I understood that Falken GTR rolled at the nismo festival the other week, it'll need some straightening before they can run that one :rolleyes:
A GTR ran in nation's cup in 2002, not surprisingly it wasn't competitive. The N-GT class cars are highly modified from their base cars, and in a global sense the monaros aren't actually far ahead (if at all), they are just very well suited to bathurst 24hrs - in fact they were not particularly competitive in Nations cup this year.
And the Nations cup cars certainly do not run stock boost, heads, cams etc etc, they are fairly open and would be pulled back into line only if they faster than the competition.
Finally, the reason the GTRs aren't competitive is 2 fold - too heavy, and the base engine is too small...
Holden were going to sell the HRT 427 but it became too expensive and they called it off.  It was going to have a production run of 100 cars or something.  I read this in the drive section of the paper about a year ago, so it must be true. :P
They were gonna sell em but not to the same spec as the bathurst!
I think it was all a publicity stunt and they were infact never going to produce 1 for the public.
i was under the impression that the nations cup was a power to weight deal fixed to different configerations, lets say rear engined sports car above $90,000, along those lines??
P.S. what engine base is the 300kw gts monaro?
The stripped down version of the Mongrel is 1600kg from memory
R34 GTR is 1550kg or there abouts stock, stripped down plus full race gear, i reckon would be the same if not lighter. I think a properly and professionally backed R34 GTR, with a good driver would be very competitive.
EDIT: Monaro CV8 Kerb weight: 1640kg (530i 4 door is lighter!, packed with TV's, Sat Nav, full leather, full 17inch spare wheel, 8 airbags, etc...)
R34 GTR kerb weight: 1540kg (wasn't far off :P)
So yeah, i reckon in full race trim, the GTR would be lighter than the Mongrel. Just make sure the 600 horsies are ready to play, and i reckon u'd do ok.
that's my tree fitty
cheers.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
