Hi Everyone,
Selling a near new R32 GTR 6 point Roll Cage. Bought this with plans to install in the GTR, never got around to it and also didn't end up liking the idea of drilling into my beauty...now with selling the GTR I don't need it anymore (or really ever did anyway :rofl:)
Price: $800
Postage: Australia wide at buyers expense
Cheers!
Craig
https://www.sau.com.au/forums/topic/299825-vic-r32-gtr-6-point-roll-cage/
Craig,
Do you have any idea who made this cage and if it is CAMS/ANDRA approved, any idea on what it would cost to ship to sydney.
Cheers Michael.
Hi Michael,
Sorry but I don't know who made it or if it is approved by either of those guys, I do know it is constructed very well. Here are some more pics for you to take a closer look. In regards to shipping I'm not sure, it would have to be through a courier, I can probably find out through my dads work if you are serious about buying and getting it up there.
http://img.photobucket.com/albums/v359/Gag...xtraParts20.jpg
http://img.photobucket.com/albums/v359/Gag...xtraParts21.jpg
http://img.photobucket.com/albums/v359/Gag...xtraParts22.jpg
This is what it packs up to.
http://img.photobucket.com/albums/v359/Gag...xtraParts24.jpg
This should fit into a gtst also id imagine.. so i may be interested. ill let u know.
Hi Jack,
I'm not an expert on differences between the GTR and GTST but I'd say with a lot of confidence that the cabins are the same and it should fit straight in :)
Let me know if you have any other questions guys.
Cheers!
Craig
Where in Vic are you? Where do the rear arm pads bolt to (parcell shelf or rear wheel arches)?
Cheers
J.
Hi J,
Im in Bendigo, bit over an hour north of Calder Park in Melbourne.
The rear arms bolt to the top of the rear wheel wells / arches.
As far being legal for road use, I'd say no :thumbsup:...but then how many people have fully legal cars :D....I think though that as long as they don't obstruct you from getting in and out of a car easily (so no door cross braces) and the parts of the cage you could hit your head on are padded properly to prevent injury they probably wouldn't care too much...its the same for harnesses as they make it harder and take longer to get someone out of a car in an emergency either by themselves or by emergency personnel.
Cheers!
Craig
Edited by R31 Gagz
Is that a Banshee Legend in the background??
?? :banana:
If your referring to the mountain bike, no its a Ghost.
Please keep replies on topic if possible and you should really only post if your interested in purchasing the roll cage :P
Cheers!
Craig
  • 3 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
