Where Is The Cheapest Place In Adelaide I Can Buy Splitfires?
got mine off the net and found they were pretty much the best price you could get at the time anyway, just depends on how long you wanna wait for 'em.
got mine for pretty cheap from sinergy,,, my least favorite place but they used to sell them cheaper then most in town,,, try HP in a Box , they might ? in Lonsdale now ?
No where is cheap in Adelaide, not many places even have stock. If you order from an online shop based in Australia that has stock you should have them in a couple of days anyway. If you need to pick them up right now you'll be paying a premium.
If they are for a R33 S2 there are some yellow jacket coil packs for sale in the for sale section.
wow ppl still buy stuff from car toys....
Haha I was just thinking the same...
I remember at Autosalon a few years back, some dude from car toys tried selling me a BOV keyring. He showed me that when you blow into it, it sounded exactly like a bov. Well, it didn't. It sounded like someone blowing into a piece of metal.
And he wanted $40 for it.
Get. f**ked.
keep your eye on the main for sale section....you can nab a bargain from some of the sellers.....also give the forum traders a PM and see what they can do for ya.....or habib-ebay.....online traders most of the time have them in stock and are decent in price
good luck mate
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
