Hi guys selling my R33 Skyline i have owned it for the past 5 & a half years with all the Mods done in that time, selling the car due to getting married recently and expecting our first child, apparently its not an appropriate family car.
Engine Specs:
RB25/30 - 20,000kms old.
RB25 head: Ported and polished, copper head gasket, ARP Head studs.
RB30 Bottom end: Machined and balanced, Arias pistons, Spool rods with ARP rod bolts, ACL race series bearings.
N1 oil and water pumps.
Custom exhaust manifold, Garret GT35/40R turbo, Tial 45mm wastegate, 3" dump pipe + exhaust.
Heavy duty twin plate clutch
LCW intercooler + polished 3" piping
LCW inlet plenum, XF throttle body, 700cc injectors, 2xBosch 044 fuel pumps + surge tank, fuel reg
Haltec E6k computer, E-Boost 2
Interior:
Complete R33 GTR Interior
Nismo 320km Dash cluster
MOMO Steering wheel
Pioneer in dash TV, Pioneer 6.5" 3 way front, Kenwood 7x10" rear, Kenwood 12" sub, Pioneer amp + Kenwood amp
Autometer oil pres gauge (Autometer air/fuel & water temp gauge not installed but will come with it)
Exterior:
400R body kit, GTR rear wing, Nismo style carbon fibre bonnet, 18" chrome rims, lowered suspension.
Car tuned by CRD making 420rwhp 20psi, reliable car driven daily.
$20 000. Plates not transferrable. also has spare interior standard interior and bonnet and brand new micky thompson semi slicks on r32 gtr rims
Phone number 0416 679 799 call after 6pm monday - friday or anytime saturday & sunday or send me a PM
If i have left any info out or you have any questions feel free to ask thanks Mick
hey champ would u consider swapping for a 2000 model holden jackaroo with 2inch lift and 33inch tyres? if ur interested sms me on 0412254468 cheers
sorry mate im after a sedan, something my wife can drive.
thanks mick
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
