hey guys.. im getting my exhaust tomorra..i hope, but i thought a better make sure what im getting is a good choice..now! bear with me as im a total car noob.. so if i dont make sence SRY!,, any way
im gettn a turbo back system.. bell dump pipe ( i thnk thast right),3 inch piping with a hi flow cat an a 4 inch cannon exhaust... $1000.00 thats including installation... so does sound like a decent price.??
(PS.. im sure he said mild steel..good/bad?) any advice/info is always good...coz a this stage im going to get done first thing in the morning...
Edited by hairyman13
https://www.sau.com.au/forums/topic/300042-exhaust-tomorra/
Without getting too technical, a full exhaust system (with muffler and piping provided plus installation) that is from turbo direct to the exhaust muffler without a resonator, would cost around the $1K mark, I have a Nismo exhaust that is turbo back - apparently cost the previous owner over $2K fully fitted, so I guess it's ok...depends a lot on the piping, installation and the muffler too.
Mild steel? I suggest you go full titanium where possible. What brand is the thing? Do your research brother instead of just going around splashing cash when it may add nothing or little performance gains to your ride.
Good luck.
https://www.sau.com.au/forums/topic/300042-exhaust-tomorra/#findComment-4985474
Good luck.
lol what the hell? Who has a full titanium exhaust? You know how much one of those would set you back! Im guessing you were referring to stainless steel exhaust? There is no need for titanium on any street driven car.
That's a tad expensive for mild steel though. I'd expect a turbo-back stainless steel system to be around that price.
Depends on the brand i guess.
Xforce catback stainless steel - $800 ; take off $300 for mild steel
Hiflow cat - $200
Front/dump pipe - $200
Labour - $300
So around $1k for a mild steel system is reasonable, depending on brand and cost of installation.
https://www.sau.com.au/forums/topic/300042-exhaust-tomorra/#findComment-4986924
$180 front and dump
$420 Rear muffler tip and center muffler
$200 Cat.
$300 3 inch mandrel bend custom Stainless piping plus install
the looks you DONT get from cops when drive past.... priceless . . . quiet as a mouse (really need to put the muffler back on though lol)
https://www.sau.com.au/forums/topic/300042-exhaust-tomorra/#findComment-4986973
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
