Know quite a few of you are using them and rave about them.
Need two new rears and I'm thinking of giving them a try. However I'm not sure which type to get. The car is a daily driver so I'm not convinced I want the RS-R simply because I like having some grip in the wet and I tend to chew through soft compound tyres very very quickly (T1Rs in less than 5k km o.O). I've read mixed reports on the SS so was considering the EVO. Thoughts? Also where best to get them from in the ACT?
https://www.sau.com.au/forums/topic/300062-federals-595/
Ok, to recommend the best tyre for you I need to know:
1. What size?
2. Is your car a daily driver?
3. What is your car's approx power at the wheels?
4. How many track days, hillclimbs, motorkhanas do you compete it (or plan to)?
5. How many kms would you travel in a year?
If you can answer these questions I can help out with the tyres :thumbsup:
https://www.sau.com.au/forums/topic/300062-federals-595/#findComment-4986198
1. What size? 235/45/17
2. Is your car a daily driver? Yes
3. What is your car's approx power at the wheels? 200rw kw
4. How many track days, hillclimbs, motorkhanas do you compete it (or plan to)? 0
5. How many kms would you travel in a year? 20,000
Mucho gracias.
https://www.sau.com.au/forums/topic/300062-federals-595/#findComment-4986357
Either 595's or the 595EVO's (which are now available) in 235/45R17 would be perfect...
I would suggest going for the 595EVO if you want slightly better grip than the 595's (the EVO's will be more comparable in performance to the Toyo T1R's), however - if you dont want to spend the extra cash the 595's will be great for your use and you should expect around 30 - 35,000kms if you drive hard... Keep checking your rotations and pressures regularly for maximum tyre life :P
https://www.sau.com.au/forums/topic/300062-federals-595/#findComment-4988132
yeah but Michael with a car a gutless as yours, with someone as bad as you driving it, who needs good tyres? you go slow enough to drive soap on ice and stay in control!
hahaha get back to work (like I can talk)
https://www.sau.com.au/forums/topic/300062-federals-595/#findComment-4991260
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
