DEFI GUAGES WATER TEMP, OIL TEMP, OIL PRESSURE, AND LINK CONTROL UNIT II AND SENSORS $900 ono
All sensors and wiring is included.
[email protected]
pickup in melbourne ok, or post at buyers expense.
* currently mounted in R34 GTT cluster, but can be easily removed.
https://www.sau.com.au/forums/topic/300283-defi-60mm-bf-guages-link-ii-unit/
no one interested defi gauges? they are in top condition.. the link controller still has the plastic protector over the buttons lol
will only sell them together, not interested in separating.
lol i'm jk.. well they will probably be for sale for a while, lots of interest... but no one seems to actually have the money this time of year.
look forward to the meet next week :banana:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
