Doing a bit of research I discovered that the A32/A33 Maxima has a 72mm TB, which is the size I want to use on a forward facing plenum when I get one.
Would anybody with a suitable plenum (Greddy, Plazmaman, etc) on their RB25 be willing to lend a hand to see if this TB will fit? If my idea works it could save a few people hundreds of dollars as you wouldn't have to buy a billet CNC item for silly amounts of cash.
This won't be until after Xmas but let me know if you're happy to help out - i'll bring beers.
https://www.sau.com.au/forums/topic/300954-rb25-plenum-tb-experiment/
you can get an adapter to fit the stock throttle body to the Greddy plenum or just fit a Q45 throttle body. why go to the effort of reinventing the wheel?
Having spoken to Plazmaman they recommended the 72mm TB over an 80mm or 90mm item for better response, so that's what i'm planning on using. Given that a lot of Nissan parts are interchangable I'd thought I'd see if this would work on one of their plenums. If the bolt hole locations are different I'll see how much TRD will charge to machine an adapter plate. The last thing I had them machine for me was insanely cheap, so I doubt this will cost much. All up I reckon it would be cheaper than a Plazmaman TB ($500) to buy the part I want & have an adapter machined.
Why spend $500 when i don't have to?
why not just buy the plenum from plazmaman that fits the std TB?
and of course he will tell you that "his" 72mm squillion dollar TB is better than an ebay 80mm one or the standard one.
In my experience changing throttle bodies on car that doesnt have ITBs does sweet FA especially boosted ones....there are plently of 350rwkw+ rb25s running around with the standard intake/TB combo
Standard TB is 60mm, 72mm should give better response - that's the aim for the car as I'm not into dyno figures & dick measuring kw contests, I just want the car to be very responsive for drifting.
Naturally Plazmaman have given me a sales pitch to sell their own TB at 3billion % mark up, so I'm trying to find an alternative. If my plan doesn't work i've lost all of $60 getting the part from Japan (Aussie wreckers wanted $110 or more incl delivery) and can still put the standard TB on.
I've never heard of anybody trying to do this before so I thought I'd give it a shot. Somebody has to think outside the box, otherwise we'd all get ripped off more often.
Im all for giving it a go mate :D
just saying that dont expect a massive difference, do you have a pic of how the cable mount etc are.
the maxima is FWD so the donk is mounted East-West so while the bolt holes might line up, but there may be a lot of stuffing around getting the cable to line up properly
R33
A32
The plug location is different as are some of the lines, but we'll see what happens once I get the plenum. The TB should arrive from Japan in a couple of weeks - i'm buying a few parts at once but most of the shops shut down over the end of year break and don't open until next week at the earliest.
Edited by a31rb25
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
