what are the rules for headlight heat range in qld?
i read in a WA topic it was 6000k or less, however 6000k only come in a HID.
does that mean a HID kit of 6000k can be fitted to stock R33 headlight casing?
any help would be greatly appreciated
https://www.sau.com.au/forums/topic/301146-r33-headlight-bulbs/
hey mate you can have Legally 8000K in any car as long as your HID is ADR Approved , which means the bulbs have a small metal shield on them to prevent your hid's dazzling the other drivers on comming traffic , also ADR approved ballasts are water sealed and have electronic ignitors
my advice is 6400K is the best they give you 2x longer beam then standard 10x better brightness to standard halogen bulbs , to fit HID in R33's use H1 HID kit , GTR Series 3 uses D2S Bulb only as they came factory with HID , same with R34's
Tip :- after hids are installed use mild cut and polish to clean your headlights to get best results
hey mate
cheers for all that
i remember reading somwhere that the limit was no higher than 6000k?
do you know what brands make adr approved hids to fit a 33?
alot of ebay ones ive heard are actually of quite good quality
hey mate most of the korean made have DOT approval same as the European made ones .. unfortnatly most ebay ones that are made in China arent DOT approved hence they are dirt cheap 70 bucks a set... DOT approved ones come with sheilded wiring , DOT approved AMP connectors, CFC free caps which are enviro friendly , and euro mark approved which gives it a higher spec class then standard xennon factroy items .... if you do buy off ebay buy korean ones thye are better ...
ah ok,
cheers mate.
am i correct in saying though that if hid's are fitted they need a projector to concentrate the light beam?
or can u put HID's in a car without projectors?
no your car doesnt need projectors at all to have HID , if you get a good quality kit you wont have the on comming traffic dazzel problem , a good kit once installed wont need any adjustments
hey mate,
thats cleared alot of things up, cheers for all the info?
is there anything else i should know about hid's before i buy and install some?
just one questions, are hid's without a projector legal though? as long as they dont dazzle other drivers?
hey mate try and get HID's with AMP connecters that are plug and play (this means you wont need to modify your headlights or your factory wiring system) , also get 6500K as it gives the best modern look and brightness 8000K onwards arent the brightest (brightness in terms of beam length) , yes you will be legal as long as you have a DOT approved or Euro ISO approved HID as i said previously the cheap chinese ones arent DOT approved usually lasts 3-6 months max ... failing that if you cant get any at all give me a pm i can get you 6500K DOT approved ones for under 250 bucks installed in your 33
hey mate
cheers for that,
im prob looking at buying some in maybe 3-4 weeks or so.
is installation hard?
i think the main thing is actually making them level to not dazzle people.
  • 1 month later...
hey mate on a S2 they are H7..
R33 series 2 fog light bulb = H7?
i tried to look at the casing of the fog light assembly and i saw an H3?
can someone please assure me of the bulb size.. cause im about to change it into HID since winter is already coming..
sorry new to skyline..
tnx..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
