Hey guys, ok , i got a 33gtst. Took it for a long drive to the country on the weekend (about 4 hours away) for a 21st.
Before the drive, i checked all the liquid levels and made sure i topped everything up, as i always do. Ran fine there..didnt drive it till a few days later, comin back to melb.
On the way back, my pasenger mentioned that that there was something dripping from under the dash. We were almost home, so dropped her off and had a look wen i got home. Theres a white container under the passenger side dash and there was a steady drip coming from it. I thought maybe the screws holding the thing together were loose, i tightened them,,nothing.. Then i noticed that on the passenger side of the wind screen as soon as i stopped driving, it started to fog up.
I used to have a prblem with an intake coolant pipe in the engine bay, so i checked and re checked it and it seems to be all good. i've checked as many hoses as i can under there for cracks, but they feel fine.
Im really confused now,this has never happened before. When I checked the radiator a while later, it had been almost drained of coolant and there was very little pressure when i squeezed the hoses.
Any of u guys kno wats going on? where this leak might be or if my aircon is jus screwed?
I cant get the car to a mech now coz theyre all closed till next week, and i might not even get the car back till after new years.
I filled up with coolant and water today and let it idle,,seemed normal,,didnt overheat wen up to operating temp.
This happened real sudden so hav no idea where it came from..,any help will be appreciated.
great christmas present lol
cheers guys
Ben
https://www.sau.com.au/forums/topic/301323-coolant-leak-inside-my-car/
Alright, i jus talked to some friends and they think its the same,,does coolant have a bad effect on the carpet? Will this affect anything else and do i just need to replace the core?
shouldn't have a bad effect on the carpet other than making it smell like coolant. should affect anything else though. in the short term you can bypass the heater core until you get a chance to replace the heater core to prevent any further loss of coolant. to do this you need to disconnect the heater hoses that run from the engine to the heater core. generally you disconnect them where they meet ther firewall.
Were you using the air conditioning?
If you were, my bet is the condensation drain pipe is blocked up and the water overflowing into the cabin. To clean it, the drain pipe is under the car next to the chassis rail. You can give it a quick squirt of water from a hose and it'll dislodge anything that's blocked up into it. Should fix it for a short while or permenantly depending on how its blocked.
Cheers
Yehh it really smells like coolant now,,, are these hoses easy to reach? Im giving this a whole day tomorro to get it done, so i'll b egoing slow, lookin at everythin.. if i wanna disconnect them, do i do it from the engine bay or from the inside?
Cheers
Well i used it a bit, dt really remember using it on the trip there. yeah i was thinking something just suddenly got blocked and its overflowing. I'll try doin this anyway,,.so i need to get under the car to see it? or is this under the carpet?
thanks for the replys guys
I did the bypass thing. Will keep it like this till after new years and i'll sort it out then,,not like a need a heater right now anyway lol.
thanks for the help guys
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
