ok, up for sale are my SSR Professor SP1's in 18x8.5+30 and 18x9.5+30 with black centres and polished lip
the rears have lower brake clearance, so they appear to have a lot of dish, although easily make it over rear brakes :D
they come with 225/40/18 dunlop lemans lm702's with 70% remaining and 235/40/18 fedeal 595ss with... err... not much left...
i will also throw in a set of 2mm and 5mm slip on spacers as i won't be needing them anymore
the wheels sit 100% flush in 33 gtst guards and require only a slight roll on the rears to fit
front left has some gutter rash that i'm getting removed when neways reopen
will post closeup pics when i get the gutter rash repaired.
sorry bout the shoddy images, they are just from my phone :)
$2000
reason for sale : got wider rims and a guard roller :)
location is vic, east
happy to post at buyers expense
contact via pm :cheers:
https://www.sau.com.au/forums/topic/301470-ssr-professor-black-18x95-30/
So if i was to fit 265/35/18 tyres on the rears, would they fit under my currently rolled guards?
Would these clear my 33GTR front Brembos?
Giving these some very serious consideration!
you'll have to come round and check them al.... where is your car atm?
they are gonna be close....
dont think you could get 265's under your guards tho... i run 245 and there is not much room... i do run my car lower than your tho...
:wub:
actually, come to think of it, the brake clearance on the rears is pretty large, so we could get 5mm shaved off them, which would make them +35's
neways should do it i think
Are you serious :wub:
yeah, it gets done a bit... there is heaps of room in most rims... with ssr's that's how they do the differing caliper clearances, they just take differing ammounts off the back of the spoke section
265/35 will fit depending how low you are and how pumped your guards are i have 265/35 on 18" +20 currently rubbing need more roll my car is 70mm off the ground though.
off topic.
can i please have details on your roof spoiler?
his guards are rolled, but not flared at all.... and the car has been resprayed, so they are what they are...
i think they will probably fit, but i would never sell to a mate without checking first :wub:
the roof spoiler is from yahoo japan / import monster... search "roof spoiler"
remember seeing an s15 there actuall... grey with a kit?
thanx for the kind words... rims are SOLD!
i got new rims... same same professors but in 18x9.5+25 all round :banana:
ahhh bud congrats... post up some pics of the +25s!!!....
nah my s15s at home sleeping ...... with no rego :down:
lol
wats funny i wasa lookin at ur page... thinkin of callin u to say il buy the rims and i saw u drive past LOL
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
