i have for 96 r33 gtst, s2
Bonnet $150
Right Guard $70
Right Headlight $60
Rigt Door with trim $70
Boot with Spoliler $80
Rear Bar $70
Rear Lights $60 pair
Front Winshield $100
Rear Winshield $100
Rear Left Quarter window $60
Rear Right Quarter Window $60
S2 Steering Wheel, (airbag) $150
Climate Control unit $100
Front Seats, No tears. $150
Rear Seats, No tears $70
Dash Board, (airbags) good condition $200
Centre Consol $50
Roof Lining $70
Rear Right Top Quarter Trim $40
Rear Right Bottom Quarter Trim $35
Rear Left Top Quarter Trim $40
Rear Left Bottom Quarter Trim $35
Floor Carpet, good condition $80
5 Stud Conversion
Front'' right and left
Brake Calipers (sprayed red)
Brake Pads (good condition)
Rotors
Subframe
Suspension Components/no coilovers
Brake Line
5 Stud Hubs
Everything Exept coilovers
All in one piece
All bolts Included
''REAR'' right and left
Rotors
Brake Line
Handbrake Cable
5 Stud Hubs
Diff Shafts
Suspension Components/ no coilovers
Everything Exept Coilovers
All in one piece
All bolts included
$1200ono
any other parts you need, ask i will have
If you need pics, ask i will post
Western Suburbs, Melbourne
Edited by boz_soljah
https://www.sau.com.au/forums/topic/301476-wrecking-r33-gtst-s2/
  • Replies 102
UPDATE !!!!
Wiper Washer Bottle $20
Radiator Overflow Bottle $20
Radiator, Fan cover, Support $100
Ac fan $20
Ac Radiator $50
Bonnet Release Cable Setup $30
Centre Dash Piece $50
Cluster Surrounding $50
Centre Console $50
Bottom Dash Steering Cover $20
Right Console Cover $10
Steering wheel cover $10
Side computer cover $10
Glove box with pins $20
Glove box, Behind part $20
hey mate, can you please PM me a close up shot of the right side tail light assembly?
if it's in good nick i'll certainly take it off your hands :)
cheers
pm sent
Hi there I'm after a aircon condenser... Do u have one for sale??? Think it's the ac radiator u have fir sale but not sure??? Can u please let me know what condition it's in and where ur located please??? Thanks heaps!!!!
If anyone has an a/c condensor for sale please let me know thanks heaps!!!
yes i do have it, pm sent
Hey mate, have you got the large heat insulated line that goes from the aircon into the firewall and normally silver in good condition?
pm sent
Do you have the plastic inner guard for the right hand pasenger side?
Also the right hand mirror assembly? My retractible mirror motor is broken.
pm sent
gday, how much for the front calipers and where are you located?
cheers
hay, im selling the complete 5stud conversion for $1000, front and rear with all parts, all suspension components, the whole lot, if you want just the front i can give it for $500, complete with all bolts, hubs, calipers, brake line, suspension components, look in pics, let me no
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
