if you can organise postage, i will sent it, i got 2much work and stuff to do. sorry man. and i think its to big to be sent by post office, i dont no any other way to send stuff,
F**ken stupid post office. how about i give you $40 for the light and postage. and you can keep or throw the wing, sound good to you?
  • Replies 102
yerr orite, snd again to same bank account and ill snd again to your adress
Shit sorry mate i forgot, Also have u got a clovebox door plus the big dash suround that goes up around the cluster, If u have could u give us a prize + post to canberra 2913...THANKS
i will chek up postage today and let you no
Done. let me know when it clears into your account, should be quicker this time as ive sent money to you before.
sweet
Floor Carpet, good condition $80
Any tears or burn marks from dropped cigarettes etc?
Does this include the boot carpet? how much for that if it doesnt?
How much for the front left hand side plastic arc guard that goes above the wheel?
Edited by Chronicles
no tears or marks, good condition
i dont no if i have boot carpet, but if i do ill give it for free if you get car carpet
plastic arc sold
0411980023
  • 4 weeks later...
  • 1 month later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
