Pics will be up tomorrow.
Location. North Shore Sydney.
Can meet half way if need be.
1. R33 Series One M-Spec Front Bar
Colour:Black
Condition:Good (Slight Rashes underneath,meh, normal)
$180 FIRM
2. R33 Stock Suspension
Condition: No Leaks, off 1994, 84,000km.
$100 ono
3. MTX 12" Sub in box
4500 Sledgehammer.
Condition: GOOD!
$200 FIRM
4. Jensen Mono Amp.
Exactly this
Condition:GOOD
$80 FIRM
Or Bundled $250 with Sub...Cheap as chips guys.
5. R33 Standard Turbo off Series One 1994.
Condition: GOOD no shaft play. Been boosted to 10psi when I got the car at 78,000km
$150 FIRM
6.Turbosmart Plumb-back BOV w/ R33 gts-t adaptor
Drilled hole underneath to make it into Dual-Port.
Cops don't see it.
$200 FIRM
Would like these all gone by 8th January as I'm goin overseas.
thanks
RJ
Edited by R 2 THE J
https://www.sau.com.au/forums/topic/301509-urgent-salesome-r33-parts-and-other/
up u go..
BOV..pending sale with adaptor.
Prefer pick up guys.
Get em while they're hottt.
Front bar $150
Suspension $50
Sub AND Amp combo $200
Standard R33 Turbo $100
Front Bumper sold, Pending Payment.
BOV sold, Pending Payment.
Still got a few things left.
Come get 'em.
hey mate im real keen on suspension!! where you located? i will pick up this sunday if your keen.. pm me plz its easier
Items Pending Payment and Pick Up:
-Front Bumper
-Suspension
-R33 Turbo
-BOV
Still got:
-OEM R33 Series One Bonnet $200
-Sub and Amp combo $200
Need these both gone guys..
Make an offer...Anything TOO stupid will just be igonred.
PM EASIER!
Parts Sold So Far.
-BOV
-Sub and Amp
-Front Bumper
Turbo pending pick up
Suspension pending pick up
Still for Sale
-Series One Rear Wing in Black KH3
-Series One Front Bumper in Black KH3
PM for these parts!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
