plugs are new (gaped 0.8), well im going to see if new coil packs will make a difference, car has been misfiring on full boost or about 3500 4000rpm
Edited by Flash89
well new coilpacks fixed the misfiring prob. no difference with the cold start
yeah when i do the idle adjust. car is prob reving around 900rpm take the tps plug off the car raises idle tp about 1200-1300 when i screw in the idle screw the rpm dont change at all. even tho the screw is all the way in too.
in the oil thread everyone has pretty much agreed that 10w40 is good for rb25's
but a 5w40 would be better again being thinner when cold
pull the air regulator (under the throttle body) out and give it a clean, make sure it goes all the way closed too (there is an adjuster)
also pull the iac valve off (one with the idle screw on it, at the back of the plenum) and clean it
clean both of them with carby/throttle body cleaner
The spring in the AAC valve should move freely. Also check the voltage on the solenoid.
Not sure about the air regualtor, I have two of them and they both cause bad cold starts. I actually think the spring is stuffed as the small bi-metallic disc does not fully close. Anyone know if this disc is supposed to remain closed with no voltage?
This thread is great when diagosing similar problems. http://www.skylinesaustralia.com/forums/Fi...ob-t174735.html
when ur car starts in the cold what rpm does it sit at and when it is hot what rpm does it sit at when start
it is easer to start when hot
what volts do u get with everything off and what it the voltage drop when u try to start and what type of battery do u have and how old is it
lets try to get this fixed.
i used to have the same problem.
Try adjusting the mixture screw... i think thats what its called. Its the screw on the manifold, on the same unit as the aac valve but on the other side. Wind that out a few turns, then start her up. If you still have trouble, get the car to temp and check your timing. I did this and new plugs and it fixed her right up.
However, it took a few goes to get it right with that screw, it progressively got better and better as i screwed out so i just did it one turn at a time. 2.5 turns got her perfect for me.
Mine was fully screwed in at first and therefore letting no air in and flooding i think... sounds like the same for you.
i think you are talking about the idle screw. and yes i do disconnect the tps when i try adjust the idle still, the rpm stays the same.
yes it fires up straight away onces its warm.
battery is like 3months old and its massive, 4x4 battery. dont ask why i just replaced the same battery that was in there before
what i would also like to do, what is the difference with cold and warm starts, like with cold starts does it give less air cause its cold which means the air would be denser??
well i think we should rule out the battery ?
do u have a multimeter?
and or a
battery tester?
if battery tester test battery to see if u have enough CCA's
if multimeter then its a bit tricky. ideally you would use the battery tester but if thats not an option then make sure the battery is fully charged. attach multimeter u should read about 12.7V and wile reading the multimeter try and start the car if voltage drops bellow 10V it might be a good idea to take it to ur local auto 1 to have it tested there.
if the battery looks angry then replace and also check your alternator. all this is. is a multimeter attached to the car with it running and you should see between what 13.5V and 14.5V then turn on head lights. the voltage should drop for a second then come back up. also check for current draw. this is the multimeter attached in series to the battery with every thing hooked up but off, set multimeter to amp's setting.
next is your air filter clean? if not clean it
have u recently cleaned your AFM if not clean it.
oil change try something with a lighter weight at cold temp
setting the A/C to "cold" will help even if u leave the A/C off because this will make your coolant bypass the heater = faster warm up
  • 4 weeks later...
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
