For Sale - LJ Torana S with RB25det
Year - 1972
Tag/Body/Chassis Numbers - ALJ14982B
Engine Number - RB25106136A
Miles - 7000
Extra Info -
Body:
Bare metal respray in custom lime green acrylic
GTR flutes
Re-chromed front bumper
Engine:
Rb25det
Intercooler
BOV
Interior:
Custom Auto-meter/Speco Dash and gauges
Custom Console
Re-trimmed Black Vinyl seats
Custom two piece carpet
Custom boot
Stereo:
JVC headunit
6 x 9 Sony speakers
2 x 10 Pioneer Subs
Blaupunkt 4 channel Amp
Wheels:
Weld Draglites
15x5 fronts
15x8 rears
Drive-line:
5 speed VL box
Custom 3 inch tailshaft
Shortened VN LSD Diff 3.45 ratio
Brakes:
HQ disc brake front
VN disc brake rear
Other:
AGM sealed battery relocated to boot with isolate switch
New rear springs
Rear guards rolled
63 ltr Vl fuel tank and pump fitted in boot
Original receipts
Full Engineering certificate and Mod-plate (NSW)
Condition - Excellent (slight scratch drivers side door)
Price - $28,500
Location - Penrith, NSW
Contact Details - 0421 555 911
Email - [email protected]
https://www.sau.com.au/forums/topic/302027-rb25det-lj-torana/
Awesome car mate, i have a torana myself but V8, your probly much better off trying to sell this over on the torana forums, i think the only person who would be interested is a die hard true torana enthusiast.
Not that it isnt worth every cent but alot of people these days would rather spend on much roomier late model turbo cars with alot more mod con's and luxury's such as power and air etc etc.....Car's like XR6 Turbo's and GTR's, Supra's etc for that sorta dollar's or cheaper.
Very nice but anyway love the green.
Goodluck with the sale regardless.
  • 5 months later...
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
