hi guys, anyone have experience welding stainless with a stick / arc welder?
ive done tafe courses and can weld with MIG, Arc and Oxy, and was going to go on and buy and train to use TIG, but currently I don't have the space for a tig welder and bottle
I want to make a simple tyre rack from stainless box section, and have been reading its possible to get decent welds with stick?
would be good to also know if theres any special requirements for this, types of rod and current required.
cheers
https://www.sau.com.au/forums/topic/302115-welding-stainless-with-stick/
Yes you can, they weld beautifully in the flat position, just make sure you use safety glasses when chipping the welds, the slag can pop out and land in your eye if not cleaned and wire brushed properly.
and dont get too close to it, slag got me on the nose! :woot:
ok are we talking about s/s stick welding or tig welding cause they are two completly different things stick weld looks similar to mig but tig welds are small and neat by the way why are you planing to use stainless steel anyway m/s is cheaper and will last unless u want to keep it for 20 years ?? thought youd like to know
+1
Unless you want to polish it or keep it out in the salt spray, mild steel is heaps cheaper, and will still last. If you're worried, paint the welds with zinc-it, and it will last. I have shelves I built over 10 years ago, have lived in moist garden sheds for the last 6-7 years and have nothing more than surface rust on the welds (I was too lazy to even paint the welds). If rust concerns you, you can always make it out of duragal, and paint the welds. Looks pretty enough, and will last a lifetime (just make sure you weld in a very well ventilated area)
I made a nice tyre rack that holds about 16-24 wheels / tyres depending on tyre width. It bolts together so I can flat pack it for storage.
Oh, ALWAYS wear safety glasses when chipping slag. I wear them under my welding helmet (helps that they are prescription glasses, so I can actually see what I'm welding now)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
