Hey guys,
Just got some work done on my car and have some parts left over.
Item: R33GTR turbos
Item Condition:Used
Reason for selling:Upgraded to Garrett 2860-5s
Price:$250 for the pair ($300 with dumps and manifolds)
Payment Method: Pickup - Cash, Paypal, COD Only
Extra Info: Very little shaft play
Item:Proflow -6 stainless steel Braided hose (Just over 4 meters)
Item Condition:Brand new
Reason for selling:Bought way to much
Price: $80
Extra Info: Never used
Item:Rb26 Injectors and Rail
Item Condition:Used
Reason for selling:Upgraded to Sard 800cc injectors
Price: $90
Extra Info:
Item:R32GTR ECU
Item Condition: Good
Price: $60
Extra Info:
Item:R32GTR Fuel pump
Item Condition:Used but good
Reason for selling: Upgraded to Nismo
Price:$40
Extra Info:
Item:R32GTR JJR Pods and Pipes
Item Condition:Good
Price:$50
Extra Info:
Item:R32GTR Cam gears
Item Condition:Used
Price:$35
Extra Info:
Item:R32GTR Airflow meters
Item Condition:Good/Used
Price:$100 for the pair
Extra Info: Never had any problems with them.
Item:R32GTR Steering rack
Item Condition:Good
Reason for selling:No use
Price: $180
Extra Info:Comes with brand new tie rod ends and rack boots.
https://www.sau.com.au/forums/topic/302233-r32-gtr-parts/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
