My first post! after months of just reading and browsing around...
well, my hr32 has really low oil pressure once the engine gets warm...
the oil pressure is okay (around 2 to 3 kg per cc) once i start my car and the engine is still cold. but once it gets warm, it drops really low on idle (around 300 to 500 grams per cc, but the warning light doesn't come on though)... when i rev the engine, goes up to around 1 kg/cc...
anyway, i checked my oil level, and it's normal... what could be the problem? any ideas?
thanks
https://www.sau.com.au/forums/topic/302296-r32-has-low-oil-pressure/
i use 20w-50... the gauge says kg/cm3 (3 is superscript)... what are kays?
Rofl I think he means Kilometres? :)
What are you using to determine your oil pressure? The standard in-dash oil pressure indicator in the R32's is notorious for playing up. Before I installed an aftermarket gauge + sender, my in-dash oil pressure gauge was telling me that I had almost 0kg/cm3 while stationary at lights.
If the car sounds + runs normal I think that it would be ok. Try installing an aftermarket oil pressure gauge + sender for a more accurate reading.
Edited by Hydroxinol
oh, ok... it has 140,000 km... i think it runs normal, but it does sound like it's breathing sometimes on idle... rpm idle goes up and down...
i am using my indash gauge to determine the oil pressure... if the gauge is the one that's messed up, are r32;s also known for messed up rpm gauges? :) mine just wants to work whenever it wants to...
i am using my indash gauge to determine the oil pressure... if the gauge is the one that's messed up, are r32;s also known for messed up rpm gauges? :laugh: mine just wants to work whenever it wants to...
Your Idle hunting(up and down) is caused by something other than Oil pressure(TPS most likely).
The Oil pressure guage itself tend to be OK, its the Oil Pressure Sending Unit(Sensor) than pooches out on us. Its located right below/beside the Oil filter. Replace the sensor and the guage will work.
And if your RPM guage is working now and then, something is just loose or mildly broken and fixable. I havent had to screw around with my Guage cluster so I cant really help.
  • 1 year later...
Hey guys. I don't know if this is a similar problem. I bought a R32 GTS a couple of weeks ago. I didn't get to drive it much because I went on holiday a couple of days after i bought it.
THe problem I'm having is that the car sometimes cuts off when I break to slow down (for lights or when i pull into my drive way). When I first bought the car, there was no oil in it and I had the same problem then. So I put in 10W-40 oil in it. Right now it says its in between the high and low level in the gauge thing. When I drive, the stock oil gauge fluctuates around 4 kg/cm^3. Just before the engine cuts, it goes down to about 1 then cuts off. THe car has 170 ks milage on it.
Can someone please advice.
Thanks.
Rusty
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
