OK guys & girls im looking/thinking about selling
Juts expressions of interest at the moment.
I havent driven this car properly for 2 years now (company car now) probably done 2,000kms in the past year or so..
I have owned the car for nearly 4 years never let me down **Always Garaged**
1996 Series 2 GTST with dual air bags, Rare Active Lsd Model, now with mechanical diff
The front bar needs replacing as it is cracked but is still useable.
Looking for around $15,500.... rego expires on November 2010
132,000kms serviced regularly 3,000-5,000kms
Plates WPN-033
EXTERIOR
R32 GTR Rims with new rubber on the Front, will supply standard rims painted black
Stealth/Drift wing
Nismo 400r Style Side skirts
Fibre glass lip on standard bar - in bad condition.
Reverse Sensor... comes in handy
Clear Nismo Indicators
INTERIOR
TRUST gear knob
Knock link
Blitz Dual - SBC boost controler
Clarion CD player
Central locking
3 point immobiliser
Window tinting
Greddy Twin A-Pillar with 1 x Air fuel ratio & 1 x Boost gauge
ENGINE
Hybrid front mount intercooler
Greddy catch can with earls firrings
Master cylinder brake brace
Sard 500hp fuel pump
Sard 650cc fuel inj. Std injectors will be provided
Sard fuel pressure reg.
Splitfire coils
Highflowed turbo by Precision Turbochargers
Brand new Braided Oil lines to the Turbo
LINK ecu
3 inch exhaust from turbo back
Blitz NUR Spec muffler
Exedy heavy duty single plate clutch (New early 2008)
K&N airpod with cold air induction through the front bar
HANDLING
Tein HR height adjustable coilovers - Also will supply original suspension
GTR rear sway bar
Tomei electronic Hicas lock kit
Brand new Brake Pads Bendix Ultimate on the front
Bendix pads on rear
Mechanical diff
Adjustable rear camber arms
Always serviced
I have had the car dyno tuned at Croydon CRD, Also fitted a new CAS- Crank Angle Sensor & new 5'' Stainlees Cat Converter.. lats tune in 2007
Power is 232rwkw on 17-18psi
The car could to with another tune now.
Most mods were perfomed by Advan Performance & Had engine Drive belts replaced earlier at SAS .
All dyno sheets & receipts will be provided
Let me know If you are interested
I don't want swap offers either..
Cheers Billy :)
Edited by WPN-O33
"greddy" pilar gauges ??
Read what it says, Greddy Twin A Pillar not the guages.
mind your own topics n i will mine.. go away, guys like u are why i dont get on this site no more.
  • 1 year later...
bump .
the car is sitting in my garage doing nothing i would rather have a gtr in there..
any interest good 33's like this are increasingly hard to find.. pm me
rego is 02/11/2011.
always serviced kms are still the same.
Edited by WPN-O33
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
