High compression pistons, larger bore, balanced bottom end, stiff valve springs, aftermarket ecu, higher rev limit (assuming it is still making power)
with an na, you have engine capacity, head + ancilliaries flow, and rpm as your basics.
So if you had a 3.1/3.2L spinning to 7000rpm......
(going to a larger bore may not be a good idea, i dont know, im not an rb30e na tuning and motor building expert. its a good idea but i dont know if it will hinder the engines ability to rev or something)
my rb30e is getting a bit sick....
how much did each of your mods cost, who did it, what exactly is the mod, where is peak power, whats the powerband like etc???
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615498
the cam is a SURECAM (btw surecam make all the cams for chiptorque, and for the rb30 hp1,hp2,hp3 it's the same cam)
headwork was also done by surecam. double springs, lifter boxes machined, port-n-polish.
104rwkw's on the chiptorque dyno, power comes on strong 2500-7000
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615645
  • 3 weeks later...
without n2o or turbo!
Turbo is probably the best bang for buck though! can probably pick up the bits you need for under $1k, and run low boost (6psi or so) on standard n/a block without too many dramas.
or the twin cam head conversion also (may as well get a turbo head put on if you're doing that).
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-638082
  • 3 weeks later...
let us know how you ran at willowbank?? i heard something about a 15.2 or something worse then previously..
went to willowbank and only got one run in. there was a huge storm and the event was cancelled. heaps of wheel spin and ran a 15.3.
got it tuned at chiptorque, not a lot more power, a little more topend.
the single afm is the holdup, once i get enough $$$ i'll install a mircotech.
with this setup as is i should be able to run quicker than 14.8, but with the tt/b's i have lost some bottom end power so i'll need to change diff gears....maybe
next time i go out to the track i'll put on some 14's and run standard rear suspension, should help the traction probs.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-666976
not enough!!!
it was only 4rwkw's, the total cost of the tt/b's was $200 plus dyno tune. so about 400 all up!
i really need to piss off the standard airflow meter! i was thinking...hole in the bonnet, round air filter, bonnet scoop.
BTW......for those that dyno there car in 3rd gear, i made 108rwkw's in 4th and 128rwkw's in 3rd.....
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-667165
4rwkw?? that's bugger all! I've seen way bigger improvements with an XF throttle body conversion than a twin throttle setup. How was your torque? improvement? I noticed more torque with the a twin throttle setup then outright horsepower. but then again, I think the twin throttle setup is more wanker factor than anything. When you going out next?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-675743
Had my car dyno tuned (again) on the weekend. Told the operator to do a run in 3rd gear and another in 4th gear, made 1-3hp difference between the gears (less hp in 3rd). Don't know where you get an extra 20kw from changing a gear?!?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-678908
i had it dyno'd at chip torque by Lachlan Riddel (the owner) so ring them and ask him.
Should take the car down there just for a couple of power runs and get a comparison. I was told it's more than likely the way the dyno has been calibrated.
Anyway, I've been told not to reveal my hp figure but I'll be honest with you, we did loose hp but we always knew we were going to with the mods we did.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-683815
    • The price of every automatic S2 stagea in japan has suddenly doubled
    • thanks mate, one of the reasons I even bought it to be fair.
    • I found parts on EFI Solutions webshop that seemed to be the accurate ones. I haven't gotten around to fitting the turbos back on the car yet since I still have to deal with the shitty crack in the engine block. But I'm confident that the bolts I ordered will fit. According to EFI they are also 7-16/24. The reason M11x1 got involved here is because it is apparently very similar to 7-16/24.
    • Well, to be fair to the car I've driven it daily for almost a decade now, although in that time only put on 50k, as it just recently passed 100k miles early this year. For the most part its been fine because I've been able to source parts from AUS like jacks jdm and a few places in Japan, some things like pads have been easy since 300z pads swap right in... I realize its probably at that time in its life i should find a new DD (but I rent and only have so much space, no garage) so new cars just complicate things. As it is older though, I recognize its about that time as with my '67 GTO to maybe side step and find an alternative, but if i can keep driving it... I want to.   That said, I may just look into a local shop that might be able to, problem is the mechanic I work with has limited space as a mom and pop operation, and he's a busy busy man, so id need to find out if he can keep the car in the meantime, which may or may not be practical for him. Maybe I'll just buy one off jacks jdm and get that refurbed /shrug.. just looking at options and what others may have to offer for advice on the matter. Like I said, its hard finding people around here who actually have one, I've had mine 9 and a half years and I've met 3 others, and they are all military, one was oem from 95 with 30k miles (rip that car... guy got hit after someone crossed s double yellow, totaled it)
    • I've noticed my rear springs sag a bit compared to the fronts. I have stock springs and KYB struts. The front wheels are pretty consistent in their ride height, but compared to the front wheels, one of the rears sits 20mm lower, and the other 40mm lower. This negatively affects the ground clearance, and also angles the headlights up. What are some some economical options for new springs? Or information like good spring rates, lengths  in order to find a suitable replacement etc Far from lowering the car, I'd prefer to raise it a bit to keep it ground clearance friendly.
