hi guys im restoring my r32 gtr v spec to 100% standard factory spec and finally its nearing completion
what i need from someone or a few people is photos of what stickers go where and which stickers they are given theyre in japanese i can only go by visual confirmation
i already have all brand new labels from nissan japan but id love to get the positioning perfect
for whoever can provide me with the 100% factory positioning of ALL labels ( i believe there is 3-4) under the bonnet on airbox engine cover radiator support panel etc i will happilly send you $50 via paypal for your time but the pictures must be detailed and the location must be factory
but if i can get a few people to help with whatever stickers they have that would also get me out of trouble as most have been accident damaged or repainted over time and stickers removed/lost/damaged
basically i need a close up of each label and another shot a bit further back to show the exact location
there is a pollution label and a few oil caution labels and 1 or 2 others from memory its been a while since i bought them so i cant remember
please pm me if you can help out and or reply here!!!!!
cheers John :blink:
u think with all the people who have GTRs on this site someone would b able to show a few pics 4 this guy , wouldnt ya???? whats up with that ?? :rofl: someone help this guy out a little
a little??
whys your writing so little..
although i do agree, someone should help this lad.. i want photos of this mint factory spec 32..
ill be quite happy to throw some pics up when its finished and all the badges and back on and so forth
its a shame that i cant get these pics because its something i really need to be correct and t me the car wont be finished untill it is done
maybe i dont have it in the best section.......??
thanks terry :happy: its the thought that counts
i know people on here arent very motivated which is why i offered the cash incentive but even that diddnt work... weird
Edited by WHITE R32
Maybe if you posted each label that you have, we could tell you/find pics of where they go. I'm sure we have all seen our fair share of R32 GTR's so maybe that would be a way. Just an idea.
no, i bought brand new genuine nissan labels
i just want to know the exact location of each label when placed onto on the car
Is there any chance......... (And do this for yourself as much as anyone) of getting you to scan these and send them to me in high res?? Do it for yourself to save them. I would truly appreciate.
i think they were about 10-12 bucks each depending what label it was....i just looked it up on fast and worked out which ones i wanted and ordered them a few weeks later they were here along with about $4000 of other stuff hahaha
  • 4 weeks later...
for those who showed interest here are some blurry bad pics of the semi finished product its still filthy and has fingerprints all over it from assembly etc... you get the idea though
Edited by WHITE R32
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
