hi guys im restoring my r32 gtr v spec to 100% standard factory spec and finally its nearing completion
what i need from someone or a few people is photos of what stickers go where and which stickers they are given theyre in japanese i can only go by visual confirmation
i already have all brand new labels from nissan japan but id love to get the positioning perfect
for whoever can provide me with the 100% factory positioning of ALL labels ( i believe there is 3-4) under the bonnet on airbox engine cover radiator support panel etc i will happilly send you $50 via paypal for your time but the pictures must be detailed and the location must be factory
but if i can get a few people to help with whatever stickers they have that would also get me out of trouble as most have been accident damaged or repainted over time and stickers removed/lost/damaged
basically i need a close up of each label and another shot a bit further back to show the exact location
there is a pollution label and a few oil caution labels and 1 or 2 others from memory its been a while since i bought them so i cant remember
please pm me if you can help out and or reply here!!!!!
cheers John :blink:
u think with all the people who have GTRs on this site someone would b able to show a few pics 4 this guy , wouldnt ya???? whats up with that ?? :rofl: someone help this guy out a little
a little??
whys your writing so little..
although i do agree, someone should help this lad.. i want photos of this mint factory spec 32..
ill be quite happy to throw some pics up when its finished and all the badges and back on and so forth
its a shame that i cant get these pics because its something i really need to be correct and t me the car wont be finished untill it is done
maybe i dont have it in the best section.......??
thanks terry :happy: its the thought that counts
i know people on here arent very motivated which is why i offered the cash incentive but even that diddnt work... weird
Edited by WHITE R32
Maybe if you posted each label that you have, we could tell you/find pics of where they go. I'm sure we have all seen our fair share of R32 GTR's so maybe that would be a way. Just an idea.
no, i bought brand new genuine nissan labels
i just want to know the exact location of each label when placed onto on the car
Is there any chance......... (And do this for yourself as much as anyone) of getting you to scan these and send them to me in high res?? Do it for yourself to save them. I would truly appreciate.
i think they were about 10-12 bucks each depending what label it was....i just looked it up on fast and worked out which ones i wanted and ordered them a few weeks later they were here along with about $4000 of other stuff hahaha
  • 4 weeks later...
for those who showed interest here are some blurry bad pics of the semi finished product its still filthy and has fingerprints all over it from assembly etc... you get the idea though
Edited by WHITE R32
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
