Hey,
Getting my car serviced just need some advice on major parts i should get inspected / replaced. (have read about 20 pages of crap in the oils thread)
97 series II rb25det, 125,000k's.. mods 3 inch exhaust, greddy oil cooler, pod filter..
parts i have already
o2 sensor
ngk iridiums BKR6EIX
greddy oil filter
So what i was looking to get down is
1. flush radiator / replace coolant
2. flush engine oil / replace oil filter + motul turbolite 10w-40
3. injector flush
4. replace the clutch boot fork
5. clean aac valve (will do this myself)
6. clean throttle body (will do this myself)
Would it be good to replace trans / diff oils at the same time (unsure when it was last done)
I've noticed a little bit of moisture (oil) around the turbo lines too, probably a good idea to get the lines checked?
Any info would help :P
Also, best place to take my 33? I dont mind travelling for good service / reasonable price..
Edited by defari
https://www.sau.com.au/forums/topic/302860-servicing-my-33/
I'd be doing all the basic stuff like oil change/flush and coolant myself if I were you. Unless of course you work a lot and don't have the time for it. At least when your doing it yourself you save money and know that it's been done properly. Too many dodgy mechanics out there.
https://www.sau.com.au/forums/topic/302860-servicing-my-33/#findComment-5023647
for the most basic stuff you can do yourself, even if you cant really wield a spanner its still quite easy and simple to understand.
1. flush radiator / replace coolant - google the rb25 manual, its free and download, tells you how to do all that
2. flush engine oil / replace oil filter + motul turbolite 10w-40 - turn into an asian with small hands cause you'll need them to get the oil filter, may aswell buy a relocation kit while your at it. Also put some proper oil in it Mobil 1 fully synthetic for instance.
3. injector flush - get some injector cleaner and run it through a tank
4. replace the clutch boot fork - ring nissan and quote this part number: 30542-69F00
5. clean aac valve (will do this myself) - swoit buy some gasket silicone (its made my loctite i think and its blue) and i gather you found the tutorial
6. clean throttle body (will do this myself) - swoit buy some gasket silicone (its made my loctite i think and its blue)
7. Would it be good to replace trans / diff oils at the same time - yes may as well again use a nice oil Mobil 75-90 in fully synthetic (if you track car) or mineral if its just on the street.
8. As for turbo lines, get a can of degreaser, spray the area, take it for a reasonable drive and inspect. All nissan motors seem to think oil is evil.
hope all goes well, otherwise hitup dan as the above members have mentioned.
Edited by 32_Dave
https://www.sau.com.au/forums/topic/302860-servicing-my-33/#findComment-5025136
If you are worried about yr injectors, I'd head to EFI Performance.
They have a fancy (read expensive) machine that will properly clean injectors, then they'll test all injectors are flowing at the same rate (within x% of your other injectors).
If you are planning to run your car at the track, I'd be making sure your fuel delivery is 100%. and getting them to clean/test injectors isn't that much.
BTW, I've been told the injector cleaner that you add to your fuel tank isn't that affective.
https://www.sau.com.au/forums/topic/302860-servicing-my-33/#findComment-5025305
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
