Item: 10 15 Row Oil Cooler w/ FULL Oil Filter Relocation Kit
Features:
- Keeps engine components at correct running temperature
- 10 15 row GReddy style oil cooler
- 290x205x50mm with a mega 600cm cooling area (front and sides)
- (-10AN) Male fittings size
- Oil cooler made of aluminium and coated with an anti-corrosive
- Full engine oil filter relocation kit
- Accepts all spin-on M20X1.5 thread size oil filters
- Sandwich plate includes ports for 2 extra gauges
- Comes with all nuts bolts and brackets
- 3 Earls type braided stainless steel flexi oil lines (125, 145 and 165cm)
- Practically a stand alone setup - easy installation!
Has been extensively used on all Nissan RB series engines
$345 including Delivery & Insurance SAU SPECIAL - FREE POSTAGE
Condition: Brand New
Contact: 0401599023 (anytime) OR [email protected]
CUSTOMER INSTALLS - Send us yours next!
  • 3 weeks later...
  • Replies 44
What do ppl think about this kit?
Looks alright, may be interested.
Can you get it with a thermostat?
Would also like to know this.
Hi mate,
Our kit does not come with a thermostat, but some customers do choose to purchase one separately.
- Brendan
  • 1 month later...
So is there a new batch in?
Hey mate,
Yes - we just got them in 3 days ago!
If you wanted to order one, we now have them in stock ready for delivery.
- Brendan
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
Hi mate, I have a genuine greddy oil cooler with lines that i bought a while back. Can I purchase the oil filter relocation kit seperately and if so will the braided hoses I have that go to and from my cooler fit the oil filter relocator?
I purchased a cheap relocator and sandwich plate that I put on my new built engine, the sandwich plate blew off the side of the block at 9000rpm and sprayed 10 litres of oil through jpc's dyno room. The thread on the sandwich plate was detroyed, so i want to be sure this wont happen agian.
Cheers
Mark
Cheers
Mark
Hi Mark,
Mate unfortunately at this point in time we do not sell the filter relocation kits separately...
But I must say our oil cooler kits have been used on some big HP set-ups and I have never heard of such damage, sorry to hear about it.
- Brendan
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
AND IT'S HERE!
Brand new batch just in - $345 delivered to your door :D
These are basically a complete stand alone set-up... can be suited to (almost) all engines
  • 3 weeks later...
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
