  • Replies 52
UPDATED PARTS AVAILABLE AND NEW PRICES - make me a (non stupid) offer people!!!
4 x Yokohama Advan Sport V103 (255/40ZR17 94Y) very good tread $800 (+$1600 new!) PRICE DROP $750
4 x Bridgestone RE55s (255/40R17 94W) a couple of track days left in them $400 PRICE DROP $300
4 x Bridgestone RE55s (255/40R17 94W) 60 - 70% tread $800 PRICE DROP $750
4 x Dunlop V8 Supercar Slicks (280/680R17) 40% tread $400 PRICE DROP $300
4 x R33GTR Rims only with centre caps, reasonable condition a few marks $1100 PRICE DROP $1000
Trust MX Front Pipes (goes from dumps to cat) dent in standard spot $250 PRICE DROP $200
2 x AFMs excellent working condition mesh not removed (removed due to D-Jetro) $100
RB26DETT standard dump pipes $50
Nismo genuine boot spoiler internal damage but should be repairable $50
Earls Oil Stat – installs into oil cooler circuit to thermostatically control oil temp. Dash 10 fittings for easy installation. Also has ports for oil temp and pressure senders. See http://www.earls.co.uk/earls/catalogue/Cooling%20Systems.pdf PART # 501ERL $200 PRICE DROP $180
Sub Box, fits 2 x 12 inch subs in R32 boot WITH rear strut brace. Made from 16mm MDF, including fittings $50!!!
R32 GTST Type M Driving lights fit in Type M front bar $50 PRICE DROP $40
RB25DET Alternator and Aircon Compressor Good condition $50 each PRICE DROP $50 for the pair!!!!!!!
ALSO ADDED:
Rubber inlet boot RB20 / RB25 $30
R33 RB25DET airbox and snorkel including filter $50
Pioneer GEX-6450TVP - watch TV on your incar pioneer DVD player. Including aerials etc
GEX-P6450TVP.jpg $100
SOLD PENDING PAYMENT
hi,
very interested in the re55s, both sets depending on visual inspection and whether the better set sale goes through.
can you pm me your mobile number so I can drop around and check them out?
Cheers.
Edited by semislickR32
on second thoughts - bare set probably isn't worth it for me as will just need to get newies within a couple of months.
But let me know if the 60/70% set sale falls through and I will pick these up.
Cheers
bud how much including postage for front pipes to brisbane...i can see the dent...but how bad it is really? no hole? very very interested.
Thanks mate.
Mitch
Edited by nissan32GTR
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
