Hi all.
I drive an r34 GTT, quite stock except of a 3 inch turbo back exhaust, brand new coilpacks, and a apexi power intake pod filter.
Doing this i have not gained any extra boost what so ever, i have an aftermarket boost gauge and it stayed the exact same as when the car was stock, thinking it would creep up with each little mod.
Its kind of like its been set to that setting, which is approx 5.6 psi and is getting stopped at that.
A good friend of mine has the exact same car, except a year older but has a very noticeable difference in power. He has factory coilpacks, factory exhaust but a HKS pod. He is pulling a lot more boost and is really really noticable when driving. Neither of us have touched the turbos or even have boost controllers.
Any ideas why this is, if anything i should have quite a bit more power than him but its the other way around.
Have they come out of the factory with different boost settings??
Are the pods making a difference?? We took his off and you can see light through it and is very thin, mine on the other hand is really compact and a bit like carboard looking.
Appreciate any help guys.
Thanks
https://www.sau.com.au/forums/topic/303145-lost-power/
standard on the cars was 5psi up till 4500rpm then up to 7psi from then on. I have a completely stock 34GTT and wasn't sure whether an exhaust would actually allow the boost to pick up or if the stock controller would stop it from going any higher someone will be able to shed some light
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025183
This stays at 5 right up to red line??
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025210
sounds like a faulty boost control solenoid
Buy a turbotech boost controoler for about $30
Will that automatically adjust the psi??, because id say my mates is up around 7-8 quite easily. and im the one with mods.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025271
Of your mods, the only one with the potential to increase boost and power output is the exhaust (by freeing up the flow of exhaust gasses). If anything, the pod will reduce power output because the engine is inhaling hot air from the engine bay, rather than cooler air from outside the car.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025470
boost soleniod will remain off for a lot of symptoms on the trouble shooting matrix in the manual . try re setting the ecu . or re plumb the t piece so its on 7 the whole time . its easy to do and very relaible
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025489
hay mate sound like your having some fun with your car! just a bit of infor for you, when asked to swap cats with your mate this is becouse if your cat, new or old has failed internaly it can cause the exhaust to block this will limit in min or major way how your turbo boost and how much it can boost to (depending on what is wrong) easy thing to check, drop it out and look at it! you factory boost solinod could be then next problem as stated thats easy to check as well change that out with your mates car, and for sh_ts and giggles if thats your problem then go for either electronic boost controlled ( no nasty boost spikes ) or a t piece bleed valve there are heaps of these to choose from most have psi settings on them you can adjust to, without the nasty guess work ( better to be safe then sorry) remember though when re setting the boost level the stock turbo has a ceramic exh wheel so from memory 10psi is max safe limit with out ca-BOOM!!!!!! i could be wrong so resurch this as there are a few guro's on this site, like discopatato for instance.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025541
what about intake mods? if your air filter is blocking the flow with a dirty/restrictive filter then it wont matter what exhaust you have.
Intake is only a apexi power intake pod filter, cant personally see a lot of air getting through it. Great filter but very resrtictive on the air flow getting through, its like a piece of cardboard.
https://www.sau.com.au/forums/topic/303145-lost-power/#findComment-5025670
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
