After spending days looking for a decent/free way to graph ECUTalk logs (without excel or datascan) I deceided a program was needed to convert ECUTalk logs to a more generic format. Mainly the time stamp which most LogViewers have difficulty with the existing format, they are now converted to the number of seconds from the start rather than a hhmmss format
I know NewKleer is working on adding this type of feature to ECUTalk, however I've been know 2 be impatient (:happy: 3 cheers 2 Peter for all his work :cool:)
Anywho, the converter is free to use, copy, share...
you'll need Microsoft VB5 Runtime librarys if ya don't have them
only known bug is with logs that span Midday or Midnight
Download Here
WinlogView is available HERE
Preview
tried datalog lab?
http://www.dataloglab.com/
looks good but has a 30 day trial limit or $$$ ( can't get it to work with ECUTalk log file either)
I'm after a free/unrestricted setup
Cheers
Bump / UpDate
V1.1.0.0 is now available, the AM/PM spanning fault is now fixed along with a few others
DOWNLOAD is Here https://sourceforge.net/projects/ecutalktowinlog/files/
** Download VB5 Runtime Library here
  • 1 month later...
hi Bundybear - I've been playing with this software myself. This software you've created looks rather cool. I work with maya an awful lot and I've got a basic way at present to read the ecutalk log .txt files into maya and then drive needles of rpm, water temp, timing etc.. as a kind of animation log.
my end goal is to use the same data to drive a 3d engine model. I'm still working on the model but it features pistons in motion and I'm hoping I can get it to display other things too like the sparks firing in the cylinder.
dl'ing your program currently and gonna give it a shot a bit later this evening (8pm in uk) :nyaanyaa:
cheers for sharing!
can it monitor the knock sensor?
I don't think so, although ECUTalk is not my software
see ECUTalk.com 4 info
I believe conzult will via custom registers
dl'ing your program currently and gonna give it a shot a bit later this evening (8pm in uk) :)
cheers for sharing!
hey Anthony
had similar ideas myself but VBz just not up 2 the task. Would love to see it come to life
my end goal is to go the CarPC route with live stats (ECUTalk), so animated logs would be a cool addition
my prog basicaly converts the 12Hr time from the log file to an 'Index' and copyz the rest of the log line, simple I know but most of the graphic log viewers couldn't deal with the time format
are you gona release either variant to the eager public ??
Freeware is Goodware
Cheers Bundy
  • 2 months later...
ok so ive updated ecutalk (see http://www.ecutalk.com) to have the extra 'Entry' column index but that didnt help at all with winlog, which needs an extra empty line up the top, which would make it invalid with datascan format. it doesnt even help with excel which was fine with the time entry as-is. so i dont think its any use at all?
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
