Location - Melbourne
I have owned the car for 5 years now and its time to move on and sell my pride and joy. Unfortunately commitments have changed and i don't get to spend enough time driving my car. This car will not disappoint it makes awesome power and handles great!! The car is maintained regularly with a service at least every 5000km, along with being detailed on a regular basis.
R33 1993 Series 1 GTS-T
Looking for - $16,500
Original 174,000km Only done 65,000km Since Engine Rebuild
Making 310kw on 20psi @ RE Customs
Fresh custom paint job
Custom Front Banana Bar
Side skirts and rear pods
Custom rear Wing
White powder coated 18" Rims
Custom Number Plates
Remote Paging Alarm
Engineered 18x265x35 Rears & 18x235x45 Front Wheels - Legal 18's
Adjustable Tein Suspension
Upgraded bushes
Bendix ultimate pads
Greedy Intake plenum
Garret 3076 High Mount turbo
Dual Flow Fuel Rail
GTR injectors
6 Boost Exhaust Manifold
Forged Pistons
Power FC
Blitz Dual Stage Boost Controller
Mspec Radiator
Nismo Thermo
New head gasket
Aftermarket Throttle body
Front mount Intercooler with custom pipes
Twin plate clutch
Lightened flywheel
Turbo back exhaust
Bosh 040 fuel pump
Shimmed Diff
Nismo Short Shifter
Momo racing Steering wheel
Colour coded gear surround
Colour coded hand break surround
Carbon Fiber inserts to doors
300km/h Speedo - White
Alpine Mp3 Head unit Car stereo
2 x 6"Rear Speaker
2 x 6" Front Splits
1 x 12" Alpine S-Type Sub
1 x 600 Watt Amp Powering the Speakers
1 x Alpine 12V Amp Powering the Sub.
This entire car is an awesome package and is well worth every dollar for the enjoyment to be had! The car has a very recent and extremely well maintained paint job which will impress all along with white powder coated rims. This car not only impresses people from its looks but also its power.
The car has been displayed at The Auto Salon GP Along with the 2006 Auto Salon Semi finals.
Please no joy riders only serious buyers.
Contact - Matt
Mobile - 0407 919 918
Email - [email protected]
Happy to post more pics if people would like to see more, or can email them as required.
https://www.sau.com.au/forums/topic/303197-yellow-r33-for-sales/
  • 1 month later...
  • 4 weeks later...
I also have an RB30DET series 2 Block which i dont need and i am happy to throw this in with the car... Its perfect if someone is thinking of doing a 25/30 conversion... The rest of the car is complete and this would be an awesome finish to the package...
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
