hey guys i am currantly tryin to sell my cefiro but not having much luck so thinkin abt parting it if i can sell enough stuff i will part
part list
rb25det just been rebuilt forged bottom end hks cam gear-3800 long motor only have reciept for $4600 for rebuild
rb25det spare motor no crank other then that ran fine abt 90000 on it- 1000
rb25det box-1500
cusco os clutch an flywheel half worn-1000
mircotech lt10 plug an play for rb25 with hand controller-900
defi infomation computer with heads up display-700
garret 25/40 turbo an manifold good condition-1000
hks rb25 oil cooler 12 row-200
300x600 cooler to fit cefiro with piping an blitz bov-400
bride bucket seat with rails for cefiro alittle worn-500
rb25 computer remaped by jun-350
dump pipe-80
nismo 555cc injector's good condition-400
bosch 044 fuel pump an new filter both brand new never fitted-300
hks boost controller-250
hks turbo timer-100
straight through exhaust fit cefiro-400
cusco 2way diff-1000
cefiro roller with r33 brake's coilovers-3500
thats about it for now will add more if i think of something these items are ono so throw some offer
hey mate, what brand of coilovers are in it and what would you be chasin for the coilovers on their own?
can supply a set of lowered standard suspension if needed to keep yours a roller.
cheers, grant
not defantly yet just seeing if i did could sell parts easy or wat if i sold engine i would
also will do drive tran package complete motor box diff an clutch setup
  • 6 months later...
Id be keen on the full interior (minus A, B and C pilar plastics, roof lining, and rear door cards), wanna put it in my laurel. What is the condition of the interior?
  • 1 month later...
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
