  • Replies 45
If there's no crash history, I might just take the whole shell + black interior you're willing??
Otherwise, can you find out how much approximately to ship front + back seats + door trims + glovebox lid thing (assuming they all match)
Edited by Nic_A31
why are you wrecking it? , complied shell? . what colour is the trim? cheers
its was a parts car when i bought it (we have 2 other ceffy's) and i bought it as a statutory right off so cannot be road registered. also the plates have been cut out of the engine bay so dunno how that effects things but at least theres no real structural damage so can be repaired as a track car.
trim is black with the cord style interior (not the suede).
after the following
-clean crack free dash
-passenger airvent and surround or just surround
-stock gay grill to cut up
-stock ceffy side mount with piping or FMIC
dash is available for $100 (includes dash top which is pristene, and surround for the instrument cluster, though this has one vent with a broken support - not visable but means the vent doesnt stay where you aim it at)
Dont have passenger vent surround (still after 2 myself, lols), grill gone already, as is the side mount.
front seats in good nic, bottom half of rear seat in good nic also, top of back seat faded around top and small top tearing around seams. all matches plus entire glove box as well (no trans surround and radio facia) also 4x door trims also matching trim, drivers side has wear mark near switches and elertic window switch has aesthetic damage. passenger front has loose pocket lining, others all good condition but all have slight fade. sell for $250 plus shipping, dunno what courrier would cost to perth, but that would all have to be arranged for at your end please. will transport them to courier in adelaide if a must but pick up preffered (i think it costs about the same)
i cant PM yet, so PM me your email and i can send u pics.. that goes for everyone :banana:
hook us up a deal on all four door trims and dash and ill organise my own couriour to pick up
Door trims are on hold for someone, but dash is available for $100 (includes dash top which is pristene, and surround for the instrument cluster, though this has one vent with a broken support - not visable but means the vent doesnt stay where you aim it at)
If the door trim guy falls through i'll let you know.
Courier can pick up from 5155 (Adelaide Hills, SA)
castor rod brackets, what the castor rod/radius rod mounts to. Bolted onto the chassis up the front... Also the sway bar D-bushes mount to it.
Available and price.
Thx
Edited by works 510
Thx
oh now im on it, sorry mate, need them for my car
Has the boot got all the trims/lining inside still?
And also the little trims that go over the back of the seat rails?
got all boot trims $65 i THINK its got all 4 seat rail covers... you mean the little plastic things that hide the bolt? its def got the drivers 2, not sure bout the other 2 as that seats been taken out... will have to scrounge thru the car (its not here atm) but $15 for them. are you SA? can you pick up?
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
