a good upgrade might be a factory GTR clutch and flywheel (from early R32) i have a billet lightweight GTR flywheel and Excedy HD GTR clutch in mine, clutch grip is phenomenal (second gear clutch drop lights all 4s with fat tyres) on RB25DE+T but you pay for it with your left leg, it is brutal heavy and bitey, Ive got a mate with a 4000lB Jim berry full monty clutch, and that's light as a feather compared.
i bought a gtr exedy clutch is thats and good
  • Replies 50
  • 3 weeks later...
how do you know if a GTS4 is a S1 or S2? Also do they use the exact same drivetrain as an r33GTR, gearbox and diff?? Also would an rb25neo mate easily in the r33 chasis.
S1-(1993 - 1995) S2-(1996 - 1998) S2 would have the following : it would have different rear wing different, front ba,r different steering wheel, have passenger airbag, different seats i think its just really obvious.
Chassis number would be ERN33 on a GTS-4, you would see a transfer case in the engine bay to the left of it ( on the drivers side) right down under the engine
all specs can be looked at here
http://en.wikipedia.org/wiki/ATTESA (look for ATTESA E-TS system)
ATTESA E-TS system is used in the following models:
* R32 and R33 (1989-1997) GTS4 Skyline
* GT-R - 1989–2003
* Nissan Stagea
* A31 Cefiro
* Infiniti G35x/Nissan Skyline (V35 & V36)
* Infiniti M
* Infiniti FX
* Infiniti EX35 (with Active Brake Limited Split for side-to-side torque split, as needed)
* Nissan Fuga (Known as Infiniti M in export markets)
Edited by niiko101
how come my cluster and another r33 cluster is different the other one has slip light and A-LSD light in the middle of the rev counter and mine doesn't could this be due to cluster change or mine just doesn't come with it.
Edited by niiko101
You must have had your dash replaced, maybe with a lower k one?
Mine has a Slip light and a 4WD light. They both come on with ignition but I've never had the 4WD light up, only the slip.
if i got a proper gts-4 cluster how would i go about wiring up the slip and awd lights?
Edited by niiko101
the plugs on the back of the dash should both be the same so it should just be a case of unplug 1 dash and plug in the other. doubt there will be any need to touch any wiring as it should just be 1 or 2 big plugs (can't remember if it's 1 oe 2 plugs)
The first picture is of an automatic gts-4, dont ask me why but the automatic gts-4 has a A-LSD light (As you can see in an owners manual for r33's) where as the manual skyline has a 4WD light instead of a A-LSD light, they are the same thing and they still have a A-LSD in the rear wherther it be auto or manual transmition......
Also that picture says the orange warning light is transmition well thats bullshit because its a engine warning light so dont believe that,
R33 GTS4 CLUSTER SERIES 1 AND 1.5
(right side of cluster) The 2 ontop you should have a seat belt reminder light (i dont think this works with compliance seatbelts), engine warning light,
Then the 3 below are, oil pressure warning light, exhuast warning light and battery warning light.
(left side of cluster) The 2 ontop are, door ajar, SRS air bag warning light
Then the 3 below are Low fuel warning light, ABS warning light, Brake warning light (used for handbrake but also reads when your low and brake fluid)
Then you should have 5 gauges, following from left - right
Water tempature, Fuel , Speedometer, Tachometer, Oil pressure
So far thats a GTS cluster, the last two things are a GTS4 thing and its SLIP and 4WD inbetween the Tachometer
Judging the second picture is yours, the cluster is a GTS one. It will work fine in a GTS-4 because its got a few pins missing that the GTS-4 cluster uses for the SLIP and 4WD lights. There for the 3 plugs on the back plug in as normal but the extra pins on the plugs for the GTS-4 for your SLIP and 4WD lights have nothing too do.
Has anyone ever seen there SRS, Fuel or seat belt lights in the working? i cant get any of them up when i have igntion on and am suspection the seat belt one wont work......but fuel never comes on when im low and just have never seen the SRS one and im not game too make that one show :D
thanks for that, lol nah i have never seen the fuel or srs one come on ither, my seat belt one works tho
Edited by niiko101
different car i know, but my SRS light comes on in my pulsar everytime i start the car. can't remember if it did in my 33 or not, been too long since i owned it
only does it for me on start up
Edited by niiko101
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
