a good upgrade might be a factory GTR clutch and flywheel (from early R32) i have a billet lightweight GTR flywheel and Excedy HD GTR clutch in mine, clutch grip is phenomenal (second gear clutch drop lights all 4s with fat tyres) on RB25DE+T but you pay for it with your left leg, it is brutal heavy and bitey, Ive got a mate with a 4000lB Jim berry full monty clutch, and that's light as a feather compared.
i bought a gtr exedy clutch is thats and good
  • Replies 50
  • 3 weeks later...
how do you know if a GTS4 is a S1 or S2? Also do they use the exact same drivetrain as an r33GTR, gearbox and diff?? Also would an rb25neo mate easily in the r33 chasis.
S1-(1993 - 1995) S2-(1996 - 1998) S2 would have the following : it would have different rear wing different, front ba,r different steering wheel, have passenger airbag, different seats i think its just really obvious.
Chassis number would be ERN33 on a GTS-4, you would see a transfer case in the engine bay to the left of it ( on the drivers side) right down under the engine
all specs can be looked at here
http://en.wikipedia.org/wiki/ATTESA (look for ATTESA E-TS system)
ATTESA E-TS system is used in the following models:
* R32 and R33 (1989-1997) GTS4 Skyline
* GT-R - 1989–2003
* Nissan Stagea
* A31 Cefiro
* Infiniti G35x/Nissan Skyline (V35 & V36)
* Infiniti M
* Infiniti FX
* Infiniti EX35 (with Active Brake Limited Split for side-to-side torque split, as needed)
* Nissan Fuga (Known as Infiniti M in export markets)
Edited by niiko101
how come my cluster and another r33 cluster is different the other one has slip light and A-LSD light in the middle of the rev counter and mine doesn't could this be due to cluster change or mine just doesn't come with it.
Edited by niiko101
You must have had your dash replaced, maybe with a lower k one?
Mine has a Slip light and a 4WD light. They both come on with ignition but I've never had the 4WD light up, only the slip.
if i got a proper gts-4 cluster how would i go about wiring up the slip and awd lights?
Edited by niiko101
the plugs on the back of the dash should both be the same so it should just be a case of unplug 1 dash and plug in the other. doubt there will be any need to touch any wiring as it should just be 1 or 2 big plugs (can't remember if it's 1 oe 2 plugs)
The first picture is of an automatic gts-4, dont ask me why but the automatic gts-4 has a A-LSD light (As you can see in an owners manual for r33's) where as the manual skyline has a 4WD light instead of a A-LSD light, they are the same thing and they still have a A-LSD in the rear wherther it be auto or manual transmition......
Also that picture says the orange warning light is transmition well thats bullshit because its a engine warning light so dont believe that,
R33 GTS4 CLUSTER SERIES 1 AND 1.5
(right side of cluster) The 2 ontop you should have a seat belt reminder light (i dont think this works with compliance seatbelts), engine warning light,
Then the 3 below are, oil pressure warning light, exhuast warning light and battery warning light.
(left side of cluster) The 2 ontop are, door ajar, SRS air bag warning light
Then the 3 below are Low fuel warning light, ABS warning light, Brake warning light (used for handbrake but also reads when your low and brake fluid)
Then you should have 5 gauges, following from left - right
Water tempature, Fuel , Speedometer, Tachometer, Oil pressure
So far thats a GTS cluster, the last two things are a GTS4 thing and its SLIP and 4WD inbetween the Tachometer
Judging the second picture is yours, the cluster is a GTS one. It will work fine in a GTS-4 because its got a few pins missing that the GTS-4 cluster uses for the SLIP and 4WD lights. There for the 3 plugs on the back plug in as normal but the extra pins on the plugs for the GTS-4 for your SLIP and 4WD lights have nothing too do.
Has anyone ever seen there SRS, Fuel or seat belt lights in the working? i cant get any of them up when i have igntion on and am suspection the seat belt one wont work......but fuel never comes on when im low and just have never seen the SRS one and im not game too make that one show :D
thanks for that, lol nah i have never seen the fuel or srs one come on ither, my seat belt one works tho
Edited by niiko101
different car i know, but my SRS light comes on in my pulsar everytime i start the car. can't remember if it did in my 33 or not, been too long since i owned it
only does it for me on start up
Edited by niiko101
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
    • Haha good old Letterkenny! If you're looking for another great english canadian comedy, I strongly recommend Trailer Park Boys.
    • I live in a French European province, within a very metric country. We hate football here and the statue of liberty was actually built in France haha. Sadly, we're currently also feuding hard with the US due to tariffs. The US is the US. Everywhere else, is everywhere else.
    • Heater wasn’t working in my 32  so I decided to pull my dash out ( sounded like a great idea at the time) so initially I was sure the heater core was blocked. When I pulled it out turns out that the heater blower actuator was cable tied so it stayed shut and this prevented the heater core from doing its job as well as flowing. so currently the dash is out the heater core is out and seems to be fine but I think I’m in over my head  and need someone that knows what they are doing to take over and get it finished. I’m located in mt Annan, nsw 2567 if anyone has any ideas or suggestions please let me know
