Hi,
Does GTR stock pressure plate fit into RB20DET motor? I'm currently in short of cash and I need a good clutch, surely can't afford aftermarket clutches. My RB are nearly stock, just FMIC, 3inch exhaust and a pod air filter. Maybe not more than 250HP on engine, never been dynoed :(
And does it make good combination, gtr stock pressure plate with rb20det standard disc? Is it direct bolt or need some flywheel modification?
If there's any other combination suggestion, please let me know.
Really need your input mates, thanks.
Edited by ariandy
https://www.sau.com.au/forums/topic/303881-gtr-pressure-plate-into-rb20/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
