  • Replies 73
ooo heaps of cars.... il be there in my gtir :blush:, try get a few mates to bring there dirty2's :) im gonna start from CP
I'll prob start out at west lakes, spose to be pretty hot , weather forecast 38
11.45am matty. ill be there. 11.15 colonades. thats departure times.
http://www.adelaidemotorplex.com.au/
fanx :D
depends what time gavin starts pullin that diff apart, said id swing around for a bit before hand
I can give you a lift if you don't mind being the slowest in the field :D
lol, slower than me hey
if ya need a lift luke lemme know, think luke and flick wanna come too, so gonna be down that way
For those that didn't make it, the cruise was sensational, the cars were stopping everyone in their tracks, I reckon we had people cruising the entire length of Port Road all at the same time. Sooooo many awesome cars out. We managed to fill the Speedboat Club, the service road and there were still cars banked back to Port Adelaide. Hopefully it sends a good message to the knobs in Parliament still holding this project up. That site would really be awesome.
Good to hear Kristian! Cheers for the call, sorry I couldn't go the whole way, had prior arrangements but atleast I showed up to the meet point :D This is a great step forward, hopefully now the government will take note of just how many passionate people there are out there who want to see something done in this state for motorsport!
I love the fact of going through the city and it was that packed full of cars left right and center!!!! AMAZING!! Felt good that most people didnt back out. Time to get our cars back on the road again!!!
