got an rb30e block.. was running when pulled out...
borrowed the head...
no dizzy(obviously as i pulled the head), rest of accessories there..
Great for a rb30de conversion..
call or sms me on 0430248318 i barely come one here..
Edited by r311111
https://www.sau.com.au/forums/topic/304029-rb30e-block-40/
it's out of an r31 so equivalent to a s2 vl block meaning all the turbo bits can fit..
if you check the title it says $40..
also if you read the sub heading it shows that i'm in western Sydney...
https://www.sau.com.au/forums/topic/304029-rb30e-block-40/#findComment-5037007
i am serioualy interested in your RB30E block...it does have the full rotating assebmly though correct?...i am however located in the USA...any chance you could possibly ship it to me?..i live in Florida
Edited by S14MARKSR
https://www.sau.com.au/forums/topic/304029-rb30e-block-40/#findComment-5055580
please Email me at [email protected] as soon as you can
https://www.sau.com.au/forums/topic/304029-rb30e-block-40/#findComment-5055588
probably easier if i was to find a local buyer, and for the stuffing around on my part, not being rude, but it seriously wouldn't be worth it ... sorry... unless you know someone in Sydney Australia that can organize it for you...
Bump!! someone take it away, tis sitting here lonely..
https://www.sau.com.au/forums/topic/304029-rb30e-block-40/#findComment-5061061
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
