Found this interesting read on theage
http://theage.drive.com.au/motor-news/enda...00114-m8no.html
Having driven some late european model cars, I do agree that car key, hand brake (as well as foot operated park brake) are definitely on its way out.
Replaced by smart keys and electronic button-operated park brake.
Clutch pedal might as well soon - even R35 GTR does not want to do anything with clutch pedal.
Lap seatbelt is on its way out - most late model cars now are fitted with lap-sash 3 point seatbelts for rear middle passenger...
Dun think mirror yet, but who knows 10 years from now, no cars will have side mirrors anymore...
https://www.sau.com.au/forums/topic/304134-endangered-specs/
what that article means is in the future side mirror will be replaced by a tiny camera. similar to the concept of reversing camera.
it has been in many vehicle concepts to have side cameras instead of conventional mirror.
Most car designers would love to get rid of the wing mirrors, as they contribute around 10~15% of the overall drag figure of a car, the technology is there to totally eradicate the rearwards blind spots with camera's but car companies are afraid to introduce the technology in case it backfires and the public choose not to drive that brand of cars.
yep, if car designers are ready to toss it into the bin, will consumers be ready to opt for rear camera instead of a conventional wing mirror for future 'upgradability' and 'expandability' to one of those rice carbon wing mirror mods or GT-mirror?
Side mirrors have always been a major wind-drag restriction. The main reason as to why they still exist on today's cars though, instead of cameras or sensors, is purely superficial.
A car without side mirrors is like a person without ears... it looks freakin wierd. Just imagine your rine without mirrors :P
Our '97 falcon has a 3 point belt for middle rear passengers. think you'll find that any car post 2000 probably would.
Most of those things i wouldn't mind, however, i would not like to drive a car without a mechanical hand brake (or, as they call them in the US, emergency brake). The American gives you a good guess why i'd like a mechanical one.
Here we go - the first resistance against evolution
LOL
Probably in 15-20 years of time anyone with a car with wing mirror will be labeled a freak - if all new cars don't have wing mirrors anymore by that time.
I think looking weird is just a matter of subjective taste of an era.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
