hey guys just a quick question if anyone knows how to fix or had this happen to them. Just got my skyline and noticed when i dont have my head unit on theres no unusual noises but when the units on it makes a high pitch noise , according to how i accelerate. any advice is good cheers
cam
https://www.sau.com.au/forums/topic/304215-head-unit-lould-pitch-noise/
Hey cam....pretty sure the problem is a bad ground! I have a 93 R33 gtst and have the same problem in my car, but just haven't gotten around to fixing it yet. i have a rough idea because i have f**ked around with the amp, rear 6" and put in new splits and head unit (not due to the noise, but because i wanted better ones) and the problem is still there, however im not an auto electrican, but a couple of my mates who are diesel fitters informed me a while ago that it is the ground, i just haven't had the time to harrass one of them enough to fix it lol. Hope that helps mate!
Brendan.
yeah as brendan said, its a bad ground. get a thicker ground cable and also make sure theres a fuse somewhere and it should fix it. the noise your hearing is the variation in RPM on the alternator, that of course corresponds to the RPM of the car when its running
floating the ground thru the antenna jack , RCA or speaker frames shorting on metal can cause a few
radios dont need big fat ground wires, they draw fark all current.
bad alternator can cause "ripple" in the A/C sine wave being converted to DC. a bit deep for most but its normally when its about ready to fail or bad ground/power wires to it.corrosion on teminals ????
record the sound and it would narrow it down quickly
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
