  • Replies 54
Dont help this year, but we will be looking at these sorts of events next year... However the k's / $ and relative to distanc hauled is always a consideration. These events are critical, because they are ideal tests for the bigger shows.
Rally Tas struggles... and that is one of the best value for money events in the country. Plus it uses some Targa stages. Why more people dont use it as Targa Test I dont know... yet Targa West Point is fully subscribed. Biggest problem is AASA v CAMS rules me thinks.
TT
TT
You would likely be more in the know than I, but ive heard that due to low numbers its likely Rally Tas will go gravel and be based on the original Southern Safari ARC event (as an ARC event)? Would be a shame, I reckon Rally Tas is a great event, great roads and burnie is a great place to hold it.
What you mean more in the know... You Nav broad minded persons get all the good gos! I feel a bit sorry for MSR as they bought a brand that was on the way down and couldnt turn it around. There is a big conflict when you are trying to run a round of the ARC in Tassie and keep it on Tamac.
I think CAMS needed to tow the Octagon line and not let ego's get in the way... Then we would have one set of rules, and in a shrinking market the best rallies on Tarmac would be supported.
We are just doing a tear down for rebuild... and either build a AASA weapon (CAMS cheater) or CAMS compliant (AASA non competitive) thiing.
Personally I think they both have it wrong, and somewhere in the middle would be good.
Anyhow I digress... The big W is off the gaspers!!!
And I cant wait to do some of these types of events (inc road trip for the crew). Can do 3x per year for the price of Tugga.
in a shrinking ecconomy and budget pull back... I think that is the way to go.
TT
Love the way the Auto Mod changed 5Lut5 to "Broad minded Persons LOL
Edited by Targa Tom
She'll be fine Timmy no panic. Just bring ya mouth guard.
Just needs tyres, brakes, fliuds, stickers, and other assorted annoyances.
Just drop it round to RGM Racing and tell em see ya with it in Townsville! Im sure thats what Russ does!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
