hey every
Alright basically ive got a r32 gts-t that had a rb20 in it however a conversion was done to an rb25 engine and gearbox, now the problems is changing the knock sensors, i have made the wirring for it with the connectors on the end however there is one knock sensor (came with engine) still in the engine itself (the one towards the front).. does any one know whats the best way to get it out.. there isnt much room to work with i am able to get to it with one hand but even if i try press both ends, wiggle it, pull it at the same time it just dosnt move.
if any one has one knows off a method they used that works then please let me know, also am i ment to use any special type off tool to remove it ?
thanks guys, Niran
https://www.sau.com.au/forums/topic/304340-how-do-i-remove-the-knock-sensors/
hey every
thanks guys, Niran
have you removed the bolt that holds it in?
