Hi Guys,
Not sure if anyone can assist in my query. 2 weeks ago I left my car outside a friends place because I had to catch a Taxi home due to my intoxicated state.
Anyway midday the next day I went and collected my car. it was a stinker of a day and the car was getting a beating from the sun all day.
I started the car, plugged in the iPhone and opened the factory screen, the sexy lass living in my dash politely told me something and the screen went black. I started again by closing the screen and opened it again, and she repeated her phrase and the screen remained off. I repeated this on my drive home and kept watching the outside temperature reading drop.
When the temp dropped to 36 degrees The Dash lady said something different and my screen came to life.
Does anyone know if theres some sort of temperature cut out or something that would have caused this.
Not a big deal but thought it was very strange! These cars are full of mystery arent they!
cheers
Lee
Hi Guys,
cheers
Lee
Exact same thing happened to mine once. Got a bit worried but everything was normal after that. It was extremely hot that day. Shouldn't be too worried about it.
  • 10 months later...
Hi Guys,
cheers
Lee
Sorry to bring up an old thread, but this happened to me today. It got up around 35 degrees, car was left outside work, no shade whatsoever. Couldn't really understand what the chick living in my screen was saying :action-smiley-069:
I started the car, windows down, aircon on full for around 5 mins then shut it off, turned it back on and voila! it works! Still curious as to what the issue is. Anyone know what she's saying?
Hi Tarun,
My car was at Perth Festival Of Speed yesterday from 8:30am - 4:00pm as part of my car club stand. It was in a middle of large clear-out area with no trees, no shades, etc. and it was 46 degrees at noon. Luckily, nothing happened like you mentioned above. But it had happened occasionally with a few owners already, so there must be something that bothers the way the car system runs when it is parked in a really hot area.
Edited by Victor.T
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
