I think you will be in trouble away from the 33, unless your thinking evo.......
I think I got you in a skyline though. RWD vs AWD isn't fair, how bout you lend me a Subie and we can battle :D
Challenge accepted! Except my subie is an auto with a broken front cv.. Meh I'll still give it a crack :bunny:
BWAHHAHAHAHAHAHAAHAAH!!! :D
Nice...
But seriously, I hope it doesnt sell so you have to keep and turn it into a full track car Luke :)
(P.S. Has anyone noticed that when you type in p-i-g without the dashes, it turns automaticly into the word 'cop'?)
cop
hahahahahahha!!!! i never knew that. this will be the new thing i have learnt for today
what i actually wanted to call someone a p-i-g?
Edited by nerm
