Hey all,
I really want a set of Autech AXIS stock wheels and am wondering if they will fit over 350Z brembos?
Anyone know?
Cheers
Cameron
I know the rotors are from Xtrail & 350z touring. . one is front one is rear. . not sure which. .
I got a quote for some 356mm rotors and 8 pots and they technically were able to fit, the 330mm rotors and brakes had fingers of room too. .
there is lots of room in the AXIS rims. . and I mean lots
Awesome, thanks for that mate!
I was thinking they would as 350Z wheels are 18x8 and 18x8.5 anyway :)
Good stuff
